Reaming – depth of cut
Home Forums Beginners questions Reaming – depth of cut
  • #436057
    Robin Graham
      @robingraham42208
      I want to ream out a 12mm x 50mm deep through hole in EN1A to H7 tolerance. I have little experience with reaming and looking on the internet I've seen recommendations for initial drill size varying between 1-2 thou and 10-20 thou below finished diameter. So I'm confused!
      My plan is to use a machine reamer mounted in the lathe tailstock.
      Any advice?
      Robin.
      Robin Graham
        @robingraham42208
        #436061
        thaiguzzi
          @thaiguzzi
          10-20 thou is fine.
          #436068
          Paul Lousick
            @paullousick59116
            I only have a standard set of drills and for 12mm reamer use a 11.5mm drill (20 thou = 0.508mm) which will produce a hole slightly bigger 11.5mm.
            Paul
            #436069
            Speedy Builder5
              @speedybuilder5
              If its the first time you have reamed this sort of material, take the advice above, but try it out on a bit of scrap EN1A first. Its a shame to spoil a piece that you have invested time into.
              #436071
              Phil P
                @philp
                Use your 11.5 drill to remove most of the material, but before you ream it take a very light cut down the drilled hole with a small boring bar, making sure you do not remove too much. This will ensure that any runout of the drilled hole is corrected before you ream it.
                I did a 10mm hole 1½" deep last night using this method, and used a 3/8" drilled hole as the starting point, it is surprising how much your drill will wander off course by the time it reaches full depth and your reamer will just follow the drilled hole and the finished bore will not be concentric to the outside of your part.
                I know not many people will advise you to do this boring operation, but it is a really important step if you want accurate results.
                As Speedy said above, have a practice on some scrap to get the hang of it first.
                Phil
                Edited By Phil P on 05/11/2019 07:02:57
                #436072
                  If it can fit in the lathe I would bore to 11.7mm as 50mm long a hole gives a drill the chance to wander and the reamer will just follow the hole.
                  Infact if it is a one off then I'd actually just carry on and bore to the finished size to give the fit I wanted on the mating part rather than ream.
                  #436075
                  Chris Evans 6
                    @chrisevans6
                    If using a brand new reamer do as said above and try in some scrap. New reamers tend to cut big on the first pass or two.
                    #436077
                    Martin Kyte
                      @martinkyte99762
                      . . . . . or 10 or 100 passes. Don't just assume that the hole will be the size printed on the 'tin' particularly if you are using a machine reamer without a floating holder. Tailstocks are never bang on, neither are tailstock chucks. By all means ream the hole but measure afterwards. Reamers are handy to produce a number of holes to near identical dimensions but best practice is make the holes first and then turn the bits to fit in them afterwards.
                      regards Martin
                      #436078
                      Steve Sedgall 1
                        @stevesedgall1
                        Just to add to the confusion the more material the reamer has to remove the bigger the reamed hole will be. Also the speed of the reamer/work will have an effect on overall size. Fast surface speeds will produce a hole bigger than slower speeds. As my old mentor used to say if you have a surface finish/size issue then check your roughing tool first.
                        #436092
                          To add to the above, for imperial holes I generally use a drill 1/64" smaller (~16 thou), unless very small (1/8" or less when reaming gets closer to broaching anyway). My biggest reamer is 3/4", above that I would allow a bit more.
                          Pete Rimmer
                            @peterimmer30576
                            Posted by Steve Sedgall 1 on 05/11/2019 09:15:05:
                            An important fact that has caught me out more than once. If you cut so much that the chips pack the flute of the reamer, the hole is going to be over-size. I've even caused a reamer to cut over-size deliberately by packing one flute with blue paper towel. Turned a tight fit into a free-sliding fit.
                            #436104
                            Vic
                              @vic
                              On stuff I’ve done the reamer cuts slightly larger under power on the lathe rather than by hand. With the reamer in the tail stock I run the reamer in manually first and check for size. If it’s too tight then I run it in again under power.
                              #436106
                              Howard Lewis
                                @howardlewis46836
                                I was always taught the "1/64" (0.015" ) undersize technique.
                                I made up holders, using ER collets, so that the reamer can float.
                                If the reamer is off centre, for any reason, it is likely to behave like a boring bar, and cut oversize.
                                There is something to be said for locating with a centre in the Tailstock, rather than holding on the Morse taper, or in a drill chuck.
                                #436169
                                Robin Graham
                                  @robingraham42208
                                  Thanks . The job is for someone who asked me to make a custom machine hand wheel to fit on a 12mm spindle – I haven't the spindle in hand, so I have to work to spec. Not my fault if it doesn't fit! If I were doing it for myself I would bore the hole then turn the spindle to fit, but I don't have that option.
                                  I have an 11.5mm drill so will try with that on some scrap before going on. I read on the Sandvik site that reamers need to 'work', but they don't give any numbers. They don't want to commit themselves – too many variables I suspect!
                                  Robin
                                  #436187
                                    Reaming is a tricky business, such that even my Machinery's Handbook declines to give any advice on this subject! It does, however, suggest that finish is improved by a low feedrate and reamer life maximised by using the highest possible (without saying what that is…)
                                    Tubal Cain's workshop handbook avoids the subject too!
                                    Chris Gunn
                                      @chrisgunn36534
                                      Robin, no one has mentioned using coolant when reaming steel, I always do, it helps to wash the chips away, and helps the reamer cut.
                                      Chris Gunn
                                      #436189
                                      Emgee
                                        @emgee
                                        Remember reading somewhere that reaming with or without lubricant also makes a difference to the finished size, can't remember for certain which way round but have never tried it as I always use lubricant, except of course on CI.
                                        Emgee
                                        #436259
                                        Vic
                                          @vic
                                          Posted by Howard Lewis on 05/11/2019 13:52:36:
                                          Yes good point Howard, I will try to remember that. Thanks.
                                          #436275
                                          Marcus Bowman
                                            @marcusbowman28936
                                            I use the rule:
                                            Up to 8mm diameter hole, drill 0.2mm undersize.
                                            Above 8mm drill 0.3mm undersize.
                                            Dormer recommend the following allowances:
                                            Below 4mm: 0.1mm
                                            Over 4 to 11mm: 0.2mm
                                            Over 11 to 39: 0.3mm
                                            Over 39 to 50: 0.4mm (Good luck with a reamer as large as 50mm)
                                            The larger the drill, the larger the allowance, and I have seen charts suggesting between 2% and 3% undersize.
                                            I agree it is best to drill smaller then bore to the undersized size, then ream, but I seldom bother under 8mm.
                                            I also agree that a floating reamer holder is best. I use one made from the Hemingway kit. Works well.
                                            Lots of neat cutting oil too.
                                            Don't let the flutes get packed, so retract and clean at intervals.
                                            Marcus
