Hi, I’m having a problem reaming 4 mm holes in aluminium plate, 6061 grade I think.
I’m drilling to 3.8 mm at about 2500 rpm then putting the 4 mm machine reamer through at about 1300 rpm with loads of WD40. The problem I get is chips stuck in the reamer flutes. I have to poke them out with a fine punch after each hole. I have tried using the reamer at slower and faster speeds but still the same problem. The holes seem to come out OK as I get a nice sliding fit with a 4mm dowel pin but having to clean the reamer each time doesn’t seem right.
What am I doing wrong? Initial hole size? Speed? Whatever?
