As you can see from my avitar I made the TE version but the roller should not present any problems.
You will need a vertical slide at the very minimum to do the milling though a milling machine would make things easier. Mine was done without a mill.
May also be worth looking at Blackgates for some of the shared parts to see if one is a better deal than the other
J
