Looking for some advice please.
These screwdrivers have been my faithful companions through several house renovations, car maintenance and numerous other projects over about 20 years.
They are now worn so they are starting to cam-out of screw-heads, and have all been replaced. However, rather than throwing them away, I am going to make the flat bits into mini pry bars by bending the tips over by 45 – 90° or so.
Two questions: what is the best way to bend the tips? I only have a butane blow lamp, a vice and a sledge hammer. Presumably I can heat to a dull red or orange then bend the tips over? Should I then quench and if so, into water or oil?
Secondly, what if anything, could I use the pozidrives for? Are the metal shafts any good to keep in stock for anything?
Thanks.
Edited By John Doe 2 on 20/10/2022 12:00:38
