A long defunct local steel fabricating company ,at one time were a bit short of work so they made some heavy angle plates,about 10 inches long with sides of 8 inches,no webs,they used flat steel plate possibly one inch thick,for their own use. the plates were welded together ,i was told that they were annealed after welding,and prior to machining. My friend who worked there aquired some of the plates when the factory closed, some years later he gave me two of these plates, they were a bit rusty so I cleaned them up and found they were out of square by about two thou over 8 ins, so I set them up on my col triumph face plate using a good cast iron angle plat eand machined them square,after ten tears they are still square.so it can be done but the welding must be first class , I have some WDS cast iron angles,and a U section which is very useful, most I picked up at s/h dealers,auto jumbles or gifts from friends,they are very accurate ,new sections from WDS are horendously expensive ,if you buy a foreign angle plate or a used one take a good sqare with you and check the angle plate for squareness ,some can be out of square.
