rapidor help
rapidor help
Home Forums Workshop Tools and Tooling rapidor help
  • #17603
    j hawker
      @jhawker30151
      j hawker
        @jhawker30151
        I have aquired an old manchester rapidor hacksaw as a project, the cast lever to engage drive is broken, so I need to strip it to repair.
        There is a large round Nut (for want of a better description) with two threaded holes in it (one has an ez-out broken off in it ) on the end of the drive shaft on the outside of the large pulley.
        Anyone Know how this comes off ?, is it nesessary to get the ez-out first ? or can I deal with it later once in bits ?.
        Cheers. Julian
        #177517
        Phil Whitley
          @philwhitley94135
          Hi Julian, I have a Rapidor, from your description of the two threaded holes this sounds like a taper lock bush, can you post a picture, as there is quite a variation in designs and fitting on rapidors.
          Phil
          #177558
          Lambton
            @lambton
            Julian,
            I have sent you a PM .
            #177770
            Lambton
              @lambton
              Julian,
              I see you have not read my PM so please look in your inbox as it may help you with your problem.
              #178013
              Lambton
                @lambton
                I wish to help you but you are not responding to my PMs
                #178026
                Ian S C
                  @iansc
                  Julian, after you log in look at the top green line, and click on your In Box, Lambton has a message there for you.
                  Ian S C
                  #178118
                  Lambton
                    @lambton
                    I have now made three attempts to contact Julian without success. I assume he must have solved the problem himself. I am disappointed to have no acknowledgement of my offer or even of my existence.
                    I give up!
                    #178120
                    Russell Eberhardt
                      @russelleberhardt48058
                      Posted by Lambton on 02/02/2015 07:18:30:
                      I give up!
                      I'm afraid that's just life on an open forum. Most people are polite and appreciative. You just have to ignore the others.
                      Russell.
                      #178132
                        Like Wikipedia, please assume good faith.
                        The poster was probably desperately searching for the answer, and having found it probably is distracted by putting the solution into action.
                        Yes it is poor practise to post a question and not let people know if it was solved elsewhere, but if we lambaste every new poster who makes an error of etiquette, other potential new members won't even bother to ask questions and the forum will eventually die out.
                        I would suggest not making repeat attempts, particularly not multiple PMs (as many existing forum members struggle with these, new members never notice the flashing icon.)
                        If the answer is more than a few sentences, the best policy with first-time enquiries is to ask for a bit more detail or just offer to help and see if the original poster takes up teh offer.
                        Ian S C
                          @iansc
                          It's a thing we'v had in the past, someone opens a thread with a question, and after a couple of pages of answers, someone asks where is the original poster? And they are never heard of again.
                          Ian S C
                          #178143
                          Lambton
                            @lambton
                            Neil,
                            I am certainly not suggesting that anyone " lambasts every new poster" quite the opposite I am always ready to provide what help and encouragement I can to anyone who needs it especially beginners. All I expect is a modicum of common courtesy – it only takes a few seconds to say thank you or provide a short explanation using email or a posting on the forum.
                            In this particular instance Ian SC told Julian exactly how to open the PM.
                            I am certainly not lambasting Julian just a bit disappointed in the lack of communication.
                            #178206
                            Nicholas Farr
                              @nicholasfarr14254
                              Hi, without lambasting anyone, I think it's all to easy for most of use to assume these days that everyone can have an internet connection on a daily basis, some people may only be able to have use of such once a week.
                              Regards Nick.
                              #178276
                              Ian S C
                                @iansc
                                True Nick, I usually go to the library if I want Broad Band so I can view U Tube, sometimes needed before answering a question, I'm lucky the library is about 1/2 a kilometre away. Julian could be miles away.dont know
                                Ian S C
