I don't think it is designed to be balanced.
Its usual to set the INSIDE of a cast flywheels rim to run true as that is the hardest part to clean up and then machine the rim and bore to suit, in a bad case the outside of the hub may also want a quick pass to clean that surface up. At least thats the way I always set them up.
J
