raising blocks
raising blocks
Home Forums Beginners questions raising blocks
  • #50774
    Cyril Bonnett
      @cyrilbonnett24790
      Can anyone tell me the thread and size of the levelling screws/bolts in the myford raising blocks?
      Cyril Bonnett
        @cyrilbonnett24790
        #50776
        V8Eng
          @v8eng
          I think they are BSF thread, not too sure about the size. Will try and check in the workshop tomorrow.
          Unless somebody else can give a definitive answer before then.
          Edited By V8Eng on 16/04/2010 20:43:58
          #50777
          Peter G. Shaw
            @peterg-shaw75338
            Tubal Cain in his book Workholding in the Lathe (WSP15) describes making his own jacking screws. I assume that these will be similar to what you want.
            Peter G. Shaw
            #50780
            V8Eng
              @v8eng
              Just a thought: are you looking to replace an original stud?
              Thread size might depend on whether you have actual Myford blocks. Possibly also depend on age of machine involved.
              Edited By V8Eng on 16/04/2010 21:40:28
              #50785
              Chris Trice
                @christrice43267
                Some later machines use metric threads throughout so worth checking with some pitch gauges.
                #50786
                mgj
                  @mgj
                  Mine are 25odd year old originals.
                  The hold down bolts (long studs) are 5/16 BSF – both ends
                  The hollow jacking screws are .525 dia across the threads. They are imperial fine but not enough is showing to count the threads. I was expecting 1/2 BSF. The spanner flats fit the original 5/16 whit spanner  but the threads  are nowhere near coarse enough for Whit.
                  I’m afraid the raising blocks don’t feature in my parts list.
                  Give Myfords a bell on Monday. They aren’t open Fri pm or Sat am  0115 925 4222
                  #50810
                  Cyril Bonnett
                    @cyrilbonnett24790
                    Thanks all, went to a local engineering company, they are 9/16 BSF
