We've been having trouble with our signals in this recent hot weather. The one which kept on having intermittent fault is the one exposed to full sun from about 1:00pm. Of course this doesn't happen when I'm there, so I have to rely on verbal reports. Why can't people write it down with all relevant info when it happens? Come Wednesday I check the gaps in the track circuiting, a bit small but definately there. Just to be safe I ran a saw down the gaps. We measured the temperature inside the signal box itself. Over 50C. This is pretty warm so I made a sunshade (baco foil and plywood as a trial). Signal now much cooler, but as soon as the sun came round, the problem came back. The gaps had closed up again, it looks as if that whole section of track is somehow ratcheting itself down the hill.
Has anyone else come across this, if so how did you cure it? We are going to experiment with insulation between the rail ends, and perhaps some kind of link between the rail and the bolted down sleepers to stop it moving at that one point.
Edited By duncan webster on 08/07/2018 16:54:18
