There are currently some gears on ebay. Probably 14 DP.
Raglan made cheaper versions of the 5” (provided mostly to educational establishments) may have 16DP gears, but even my Little John was fitted with 14 DP gears (it was a QCGB model).
The gears are all (I believe) simple spur gears with a plain central bore and keyed together by a pin (in holes close to the bores, where appropriate), except for the gears on the spindle and lead screw drive.
The 5” used thicker gears than the LJ, for all change wheels, I believe.
Measure the gear diameter and tooth count to calculate the DP, to be sure – is my advice. Tumbler gears are 2” in diameter so only need to count the teeth to easily find the DP.
Gears are easy enough to cut with only the lathe, if you don’t have a mill. There are vids on youtube.
Edited By not done it yet on 17/03/2021 08:14:58
