Mine has the slotted cross slide – where my rear parting tool sits almost permanently.
Another important thing might be ‘which end of the apron is the hand-wheeel’?
Some were sold (probably to educational establishments, mainly) with the wheel at the tailstock end. These versions may not have all the apron improvements one might expect. There are some who complain of the wheel being too close to the hot swarf, but the auto long travel trip can avoid most of that. I use it whenever I can – which is nearly always.🙂
Mine has the mechanical variable speed and also runs from a VFD, so well sorted for a very wide speed range with most of it available at maximum power. No problem with that belt.
Mine was most definitely far better value than a myford.
