Disappointed with my own effort, I ordered a Canaduino MSF receiver which arrived last week.
My ultra-basic TRF receiver used an old Long Wave Ferrite Rod antenna capacitively loaded to tune at 60kHz: not ideal because the quality of a tuned circuit depends somewhat on the inductance and capacitance being reasonably matched. Achieving resonance with a big inductor and tiny capacitor, or a big capacitor and tiny inductor, are both compromised. As always the middle way is best.
Although the Anthorn 60kHz MSF time signal was visible on an oscilloscope, my receiver picked up so much electronic muck there was no chance of decoding the signal with an Arduino. I have a couple of communications receivers and they showed the signal to noise ratio in my home from Althorn to be poor : it varies by day and night, but is always marginal due to man-made noise. My home is surrounded by telephone wires and a pole mounted power distribution system, both of which emit high levels of interference from 0Hz to 25MHz, and even beyond. The mains borne noise is generated by almost anything unfiltered my neighbours plug in : switch mode power supplies, electric motors, VFDs etc etc.
The Canadian receiver is a much better bet than my TRF. In addition to a better engineered Ferrite Rod antenna, their receiver comes with a 60.003kHz crystal, which, being sharply tuned, is much better at rejecting noise. (The receiver also has automatic gain control and the electronics needed to create nice sharp pulses for input to a computer.)
Had two misadventures fitting the crystal: opening the well packed plastic box, the tiny crystal flew out Good job I saw it out of the corner of my eye, because the gremlins hid it under a bookcase, Later, soldering the crystal to the board, I thought 'must be careful not to get solder on the chip next door', at which point another gremlin twitched my elbow and deposited a solid blob across 4 pins. Time to solder crystal, 90 seconds, then 20 minutes wasted carefully removing unwanted solder. My eyesight and clumsiness don't go well with Sub-miniature devices.
Anyway, the receiver survived and it works! Alas, not quite good enough. Although the LED flashes more or less correctly, the recovered signal is still unreliable. Next step is to box the receiver up neatly with a battery and take it walkies. Pretty sure it will work correctly when moved away from the overhead street wiring. To fix this problem, I have to buy another house!
Plenty of reports of MSF clocks misbehaving. Having looked closely at the signal received by mine, and read Canaduino's advice, the clocks are vulnerable to man-made interference. I suspect many clocks only get a decodable signal intermittently, and the ordinary crystal movement is corrected randomly, but 'good enough'. Others, may work perfectly well until you, or a neighbour, plugs in a device that f*rts on 60kHz. My consistently high noise problem is probably common too: it's the sum of many mucky devices nearby drowning out the Anthorn signal. May not actually be necessary for me to move house, because I can get a usable signal from a communications receiver, and the Canaduino might work if fed with a well aimed loop antenna on the roof. More trouble than I care for.
