Rack locomotive of 1812
Home Forums Drawing Errors and Corrections Rack locomotive of 1812
  • #47724
    Eric Cox
      @ericcox50497
      The drawing and photograph of part 33 (piston rod) shows the rod being 3mm dia. with a 5.5mm dia lip. The text says the end should be turned down to form a shoulder. Which is correct.
      Eric Cox
        @ericcox50497
        #47739
          I would say that the shoulder and lip are the same thing, the short end being turned to suit the 6ba thread.
          Jason
          #47808
          Eric Cox
            @ericcox50497
            The end is turned down for the 6BA thread but from a 3mm Dia. bar, so where does the 5.5mm come from.
            #47825
              If you look at the drawing and the photo there is a 5.5mm dia flange thats 1mm thick and 11mm from the the end. You will either have to it from 7/32 reducing teh ends to 3mm and 0.110 or silver solder a flange onto some 3mm rod and just turn the top down to 0.110 for the 6BA thread.
              I assume the cross head bears against this flange and is retained by the 6ba nut
              Jason
              #52658
              John Stuart 1
                @johnstuart1
                On the boiler drawings in ME is there an error on the measurements of the bosses as the numbers just don’t add up, I have moved the safety valve bosses to 15mm from the ends of the boiler, next also on the boiler layout the fire tube/box  is 6mm longer than the boiler and I imagine the fire box door sits on this 6mm but on the drawing it shows it the other way around, has anybody got any thoughts on this.
                Eric Cox
                  @ericcox50497
                  Another anomaly shows the pins on the track at 15.52mm but the text states 16.00mm.
                  Which is correct.
                  #53363
                  John Stuart 1
                    @johnstuart1
                    If like me you have found great difficulty in tracking down the 22mm part cross over and almost given up as it’s made from 100% unobtainium and only bought in a pack of 10 to special order, I fell lucky today and found a local firm with 4 on the shelf at low cost so if like me you were having trouble I can share the information as to the whereabouts (north west) or even post you 1 if need be.
