Concerning tightness.
I believe that according to Bridgeport, R8 recommended drawbar torque is around 25 – 30 ft lb as bing "normal tightening torque" for the drawbar thread. However translation of normal tightening torque into actual ft/lb does vary over the years and is complete pain to track down. Found it on the internet a couple of times and wrote it down but source has now disappeared. I think Tormach also suggest about 30 ft lb too but can't track that source down either.
I did just find a handy dandy tightening torques for fasteners table form Norbar, the toque wrench people, at **LINK** which says 26.5 ft/lb for ordinary P grade fasteners and 50.3 for better S grade ones in the 7/16 – 20 (UNF) R8 collet thread. Norbar say P grade fasteners have 35 tons/psi Ultimate Tensile Strength. Bridgeport drawbar suppliers usually claim them to be made of cold rolled steel which, for the more ordinary grades, tends to be quoted as having a UTS of 70,000 psi which is near enough the same. So having gone all round Robin Hoods Barn it looks like 25 – 30 ft lb is reasonable.
According to Techniks main data site **LINK** or summarised in a nice table here **LINK** ordinary ER-25 is around 77 ft-lb but the ball bearing mini-nut only needs 29 ft / lb. I imagine other breeds of ball bearing nut are similar so looks to be a no brainer to use a ball bearing nut on a lightweight machines. One tends to think that ball bearing might make the nut more likely to back off but clearly this isn't the case, at least not for professional gear.
With ER collets its important to remember that the holding part, full length on larger sizes but only part length on smaller ones, must be filled and the collet torqued up properly if specified run-out is to be achieved. The ER system uses the nut to assist alignment duties as well as providing the tightening torque so, theoretically, accuracy is compromised by the very design of the system. In practice everything is a compromise of some sort or other. The designer selects which ones he (or she) can live with in the application so that if used properly there are no significant real world issues.
Not sure that 77 fl/lb torque on my Bridgeport spindle to tighten the E25 set up doesn't count as a real world issue but I use the ER's about once every third blue moon after second muck spreading so no great worries. If they were my go to system I'd have bought a ball bearing nut years ago.
Clive.
Edited By Clive Foster on 14/12/2018 14:09:40
