Hi Kevin,
Your lathe appears to be this one LINK and I believe it has a 100mm (4" ) centre height. It looks like Warco offer a couple of QCTPs for that centre height LINK
The centre height on my lathe (WM180) is 90mm and I have added a QCTP from Arc Eurotrade, the model 250-100 which required some slight modification. LINK
If you take the measurements from your lathe it should be easy enough to work out which one of those I linked to would fit. If still unsure, as John says have a chat with Warco, or any supplier, I'm sure they'll get you sorted.
Ed.
Edited By Ed Duffner on 12/06/2015 21:43:06
Edited By Ed Duffner on 12/06/2015 21:43:18
Edited By Ed Duffner on 12/06/2015 21:44:58
