I’ve had my mill a few months now …
What sort of mill is it. Fitting fancy cutters to a basic mill probably won’t improve it much.
When I got the mill I bought a small selection of 2 and 4 flute cutters in a couple of diameters from ArcEuro. These have served me well and allowed me to learn, however some YouTube education has led me to believe that I will get better results with better cutters.
Youtube has no quality control. It’s a mix of good and bad advice. Trouble is the best videos require an experienced machinist, who is also a good communicator, and knows how to make a watchable video. Not that common. Quite a few are made by inexperienced machinists with video skills, and it can be fun watching them to see how many inadvertent mistakes they make. Another group are ‘influencers’ – rewarded in some way to push products, and therefore prone to bias.
My experience of ArcEuro is good. I’d describe them as a careful vendor of mid-range products, priced to suit hobbyists, but capable of reasonable performance on hobby machines. You need to ask exactly what a top-end cutter will do for you. Briefly:
- Will be to specification out of the box – no blunt, mis-ground, or poorly hardened. This is important to professionals because time is money, much less so to hobbyists who don’t mind a delay replacing a dud.
- Long life when run at commercial speeds. Again, important to professionals, but very few hobbyists run cutters at anything like commercial rates. Our machines lack power, speed and rigidity, and we probably don’t cool or remove swarf to spec either But in general, posh cutters last a bit longer than cheaper ones. I’ve not found it worth paying the extra, but it depends on what you do in your workshop.
- Guaranteed balance for high-speed running. Probably a waste of money in a hobby workshop.
- Making it less likely that poor results could be due to a defective tool. That allows the operator to concentrate on what he’s doing wrong! But a bad operator can quickly convert an expensive cutter into a dud: I’d rather learn on mid-range cutters and check them for damage with a loupe, rather than fling money at well-made cutters in hope they’ll survive my blunders.
- Bragging rights down the club!
- Also acceptable if coughing up makes you happy. Many enjoy using good tools, even if they make no practical difference. Reassuringly expensive is a thing.
So I really wanted to get peoples opinions of the validity of this, and if it is correct what sort of budget should I be allowing for cutters, which are the better makes, and where is good to buy from?
Simple answer, assuming lots of cash, is someone like Cutwel. I doubt they get a lot of business from hobbyists though, because as a group we lust after industrial quality only until told the cost! A nice 20mm 4 Flute Multiple Helix K2 Coated Carbide Chamfer Prep Weldon Shank End Mill from Cutwel is £124.10 plus VAT, and maybe postage. Are you up for spending on that scale Robert?
My experience, based on relatively light experimental work in a Far Eastern equipped workshop is that posh cutters don’t make enough difference for me to spend big money on them. Someone who works faster on high volume output needing a quick good finish might get a different answer, one that might include upgrading their machines as well.
Budget depends entirely on how much metal you cut. Many small cutters are consumables, and it might well be cheaper to burn through several inexpensive cutters rather than tie money up in posh one.
Where not to buy from may be helpful. This is difficult: ebay and similar do offer genuine bargains. Trouble is they are mixed in with carp and it’s hard to know what’s what. Avoid too cheap, vendors who don’t have an engineering track record, and imports. Not that they are all dishonest, but a proportion are flogging manufacturing seconds, worn tools in new boxes, forgeries, and factory rejects. The reputable UK suppliers are unlikely to send complete rubbish, and should refund/replace if a lemon gets to a customer.
B
