I would be choosy and buy the best cutter holder within budget. You can source your inserts from any of your choice, but if the holder is not a good fit to the inserts, is flexible, slightly the wrong angle, poor threads in the screw hole, etc. you are stuck with it.
At the same time, if you total one – due to inexperience – it can be an expensive lesson!
It really depends on the intricacy of your work. Bigger tools are great for long, straight surface cuts; smaller ones are necessary for those jobs where access is more diffiCU
lt.
I think there must be many more discussion threads on this topic than just the one you have listed. Plenty of u-toob expanation/discussion, too. I expect you will eventually buy a set, then end up buying better ones in the future, or realise they are not always all they are claimed to be.
Edited By not done it yet on 06/02/2017 17:42:11
