Quality Finish
Quality Finish
Home Forums Beginners questions Quality Finish
  • #492046
    martyn nutland
      @martynnutland79495
      Hello
      I wonder if the experts could give me some advice on obtaining a high quality finish on a part.
      I'm making track rod ends for a vintage Austin Seven. As many, many of you will know; on an Austin Seven a fork on the end of the track rod clenches a steel pin by means of the ubiquitous cotter pin, then the steering arm/track rod arm has a bronze bush to pivot on said pin.
      I'm using EN16T at diameter +/- 9.5mm and for mechanical rather than purely cosmetic reasons I'd like to achieve as near to a glass-like finish as I can. Recently I used some steel described as 'polished' from my supplier here in continental Europe (the excellent RC Machines in Luxembourg) but found the tool tended to tear the surface and leave it rough how ever sharp the insert or light the cut. I don't want that to happen again.
      I won't be tryng to harden the pin in any way – the mileage doesn't warrant it.
      Any advice and many thanks in advance. Keep well.
      Martyn
      martyn nutland
        @martynnutland79495
        Getting a ‘glacial’ surface on a part
        #492047
        Paul Lousick
          @paullousick59116
          What tool are you refering to ? And a photo of the part would be helpful for advise on what to do as I have never seen a track rod for an Austin 7.
          Paul.
          #492049
            Posted by martyn nutland on 23/08/2020 07:40:13:
            A decent depth of cut to make the insert work will often result in a better surface finish, plus a reasonable feed and tip radius.
            Failing that work through the grits with abrasive.
            #492051
            Kettrinboy
              @kettrinboy
              On 16t steel I would go with a HSS tool with say a 0.4 mm rad put on with a stone and use a quality cutting oil , works on all the usual alloy steels like 19/24/36b ,and the finest feed your lathe will do, if you turn a fine finish then polishing is quick and easy.
              #492053
              Howard Lewis
                @howardlewis46836
                For the ultimate, turn to about 0.0125mm oversize, and then polish with emery and oil, using finer and finer grades, possibly 600 wet'n'dry., until you are at the required size.
                Being an Austin 7, you will actually be aiming for an imperial size, of course
                Howard.
                #492061
                Nick Hughes
                  @nickhughes97026
                  I've had some good results Roller Burnishing shafts, by replacing the Knurls in a Clamp type knurling tool, with Deep Groove Ball Races.
                  Nick.
                  #492062
                  Nigel McBurney 1
                    @nigelmcburney1
                    Use HSS tool with about 15 degrees top rake,small radius on tip and hone with an oilstone,soluble oil is ok though a drop of liquid ROCOL helps, reduce speed to 40 to 50 feet per minute.
                    #492067
                    Dave Halford
                      @davehalford22513
                      Martyn,
                      I've found inserts for alloy CCGT32.51-AK H01 will give a much better finish on teary steels, they are really sharp.
                      #492068
                      Martin Kyte
                        @martinkyte99762
                        Turn as fast as possible.
                        regards Martin
                        #492072
                        ChrisB
                          @chrisb35596
                          An HSS tool ground as a shear tool will give you a mirrior finish. The depth of cut should be minimal say 0.02mm and preferably supported at the tailstock end as this will generate some sideload.
                          #492117
                          Mick B1
                            @mickb1
                            Posted by Nigel McBurney 1 on 23/08/2020 09:34:28:
                            That's more-or-less what I do too.
                            #492125
                            martyn nutland
                              @martynnutland79495
                              Many thanks all. HSS, fast, light, lubricant, stone. Got it.
                              M
                              #492141
                              Brian Sweeting 2
                                @briansweeting2
                                Use a shear tool to obtain a smooth finish then fine abrasive.
                                #492142
                                Tim Stevens
                                  @timstevens64731
                                  When you get the surface to the stage that it is silvery and you can barely see scratches, spin it fairly fast and apply a rage with metal polish (Solvol AutoSol used to be favourite) or use bodywork finishing products. This will produce a much more brilliant surface – like chrome but still only steel.
                                  Quite why such a surface is required I'm not sure, though.
                                  Cheers, Tim
                                  #492781
                                  martyn nutland
                                    @martynnutland79495
                                    Many thanks again for all the good advice.
                                    I didn't know about shear tools which seem essential to the process.
                                    Strangely enough, Tubal Cain has a whole video on making them and I'm now studying this.
                                    Martyn
