Q1 Detail photos of prototype
Home Forums Locomotives Q1 Detail photos of prototype
  • #50165
    Nigel Bennett
      @nigelbennett69913
      I was at the NRM last weekend and banged off a few shots in case anybody is following Nick Feast’s articles in ME. This is the first few; I’ll keep adding to them. There’s a separate thread for the tender.
      Injectors & Cab Underside:
      [image]
      Injectors & Cab Underside2:
      [image]
      Lubricator Atomiser – LH directly above the Lubricator:
      [image]
      Eccentric Rod:
      [image]
      Eccentric:
      [image]
      Fireman’s seat:
      [image]
      LH Frame at throatplate:
      [image]
      RH Frame at Throatplate:
      [image]
      Nigel Bennett
        @nigelbennett69913
        #50166
        Nigel Bennett
          @nigelbennett69913
          Part 2:
          General front 3/4 – can’t get much of an overall view in there at the moment, but there are enuff pictures of the whole thing around!
          [image]
          Front buffer beam (& cylinder drain pipes):
          [image]
          Piston valve covers, front LH:
          [image]
          Injector pipework:
          [image]
          Injectors:
          [image]
          Injectors again:
          [image]
          LH Lubricator:
          [image]
          Lubricator drive:
          [image]
          #50167
          Nigel Bennett
            @nigelbennett69913
            Part 3: LH Sandbox:
            [image]
            Steam Reverser:
            [image]
            And again:
            [image]
            Sandbox:
            [image]
            Sandbox – Trailing LH:
            [image]
            Reverser – RH (?)
            [image]
            Loco & Tender connection:
            [image]
            Front Buffer Beam Detail:
            [image]
            Edited By Nigel Bennett on 26/03/2010 12:08:59
            #50168
            Nigel Bennett
              @nigelbennett69913
              Valve spindles:
              [image]
              Weighshaft:
              [image]
              Weighshaft Bearing RH:
              [image]
              Balance weight on main driver:
              [image]
              Buffer Beam:
              [image]
              Backhead:
              [image]
              Lower down:
              [image]
              Driver’s seat:
              [image]
              #50169
              Nigel Bennett
                @nigelbennett69913
                Backhead again:
                [image]
                Main Driver:
                [image]
                Coupling Rod Knuckle joint LH:
                [image]
                Rear Coupling Rod LH:
                [image]
                Piston valve covers:
                [image]
                again:
                [image]
                And finally (for the loco), RH horn:
                [image]
                #50174
                nick feast
                  @nickfeast85472
                  Well done Nigel, most helpful. The reverser is on the left(driver’s) side by the way.
                  Nick Feast
                Home Forums Locomotives Topics
