Punching small slots in brass
Home Forums Workshop Techniques Punching small slots in brass
  • #715746
    sparky mike
      @sparkymike
      I need to punch some small slots in some 1mm.sheet brass. Slots are 1mm X 6mm.
      Any ideas welcome.
      Mike.
        I would think you need to make up a punch and die set. Punch could have the 1 x 6 end milled onto the end of some silver steel. Die milled slot if it is round ended, if rectangulat then make from 4 pieces of gauge plate. Harden and temper both.
        #715757
        bernard towers
          @bernardtowers37738
          As Jason says and dont forget to turn the die over and mill the slot 7 x 1.5 to within a millimetre of the top to give relief for the punch and if poss relieve the punch. to make it easier to be removed from the brass strip
          #715778
          Clive Brown 1
            @clivebrown1
            As a possible time-saver, you might get away with avoiding the need for making a die by punching out the slots onto a block of lead. Perhaps success depends on how clean and neat you require the slots to be, and maybe 1mm brass is a bit too thick for this technique.
            #715781
            sparky mike
              @sparkymike
              Other ways I have considered is plasma/laser cutting, but not sure if they can cut to those dimensions.
              Another way could be to chain drill and finish off with a fine milling cutter. The ends of the slots are not critical would not concern me if they were rounded. However I could finish the slots off with a needle file if I have one thin enough.
              Have to try a test one first. I do have a set of very fine printed circuit drills, but not sure how long they would last drilling brass. I only have four slots to do at this time, so obviously not worth buying a press tool.
              #715782
              Bazyle
                @bazyle
                I suspect there is more of a problem when the slot width is so small compared to the thickness of the material. Have a look at your good old paper hole punch, you know for putting sheets into a loose leaf binder. Note how the end of the punch is not square but scalloped on the end. This produces a shearing cut rather than brute force hammer blow.
                #715790
                noel shelley
                  @noelshelley55608
                  Spark eroder ! Noel
                  #715799
                  duncan webster 1
                    @duncanwebster1
                    On noel shelley Said:
                    Spark eroder ! Noel
                    #715843
                    JA
                      @ja
                      1mm slot cutter.
                      JA
                      #715852
                      Russell Eberhardt
                        @russelleberhardt48058
                        Depends on how many slots you need to cut but for a small number I wouldn’t bother making a punch.  I would mark out carefully drill just undersize and use a piercing saw blade in a fret saw frame.
                        https://www.cousinsuk.com/product/vallorbe-super-pike-saw-blades
                        Russell
                        #715865
                        Journeyman
                          @journeyman
                          For just 4 holes  at 6mm x 1mm I would chain drill and use a needle file to clean up.
