Recently I got some plans for a pulse jet engine from JohnTom.com named "Pulso #1". It was a quicky engine to build, just need to get spring steel for the reed valve.
I remember doing a lab test as a student on one with a 3" diameter tail pipe. It ran at about 100Hz. The whole thing glowed bright red, made a horrendous noise and resonated one's body cavity. Most unpleasant.
Dont run it for more than 10 seconds in a static state otherwise you will burn out the flap valve, these things are designed to run with a flow of cold air into the intake, I bought one to make into a land speed record car after a while it dawned on me that about 5 secs after letting it go it would have travelled too far away to be seen or be controlled so I sold it but the noise is memorable.
Dick
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
