The best ones are water jet cut from spring steel stock. The petal thickness depends a bit on the fuel being used as well, so some have 0.006 inch, 0.007 inch and 0.008 inch thick spring steel petals made. The hobby king petals work quite well for the standard or the sport jet class to 150mph or so. To go faster requires testing with other material thicknesses and keeping records of the day temps and humidity.
Laser cut ones are not as fast as the waterjet cut ones . It maybe due to the very small heat distortion from the cutting of the petals from the laser.
Edited By Neil Lickfold on 11/12/2021 00:36:11
