Hi, yes it's the weekend and daft questions abound.
I'm trying to work out a problem with a clock I'm making. At the moment it requires 2.5kg to run for 1.5 days.
Now that's fine but I'm lazy. I want it to run for at least a week. There are two options mount the clock so high of the floor it would need to be upstairs with a hole in the floor. Not practical as I live in a bungalow.
Or use pullies to increase the distance the weight travels.
But that means I'd need a pulley ratio of 4:1 and at least 12.5kg of weight. Now as the clock is wooden anyway. To give me enough torque. That's a no go.
But and this is the big question. If I use a gear train with a ratio of at least 4.5:1. Would I get back the torque lost because of the pullies?
I realise some torque will be lost through friction etc. And normally the speed would be so slow as to be useless but the speed will be regulated from the clock not the weights. And so as long as the torque doesn't exceed the original tolerances would it work?
And if so what gearing should I use. A simple two gear train or more? And if not is there any other way of increasing the time between windings without needing steel reinforcement in the walls?
Sorry if my terminology or anything else is wrong but I'm just a daft old wooden top.
Thanks
Izack
