Publication Recommendation
Home Forums Beginners questions Publication Recommendation
  • #52180
    Clive Turnbull
      @cliveturnbull59507
      Trying to locate a good publication on turning and use of the lathe. I managed to borrow EITB H2 & H23 Turning Instruction manuals but I have to return them. They are just what I need and I thought I would be able to buy them from Ebay or Amazon but no luck. My only option is to copy each page but a bit of a marathon!
      Can anyone recommend something similar or even advise me where to find these publications.
      Help would be appreciated.
      Clive Turnbull
        @cliveturnbull59507
        #52183
          You can’t go far wrong with the old classic “The Amateur’s Lathe” by L.H. Sparey
          ISBN 0-85242-288-1
          Jason
          #52185
          John Shepherd
            @johnshepherd38883
            Another book you might consider is ‘How to Run a Lathe’ originally by South Bend Lathes. It originally dates back to 1942 and although it is written around their products it has a lot of information that is as good today as it was then. It has been republished by Lindsey Books and at about £6.75 it is good value IMO.
            ISBN 1-55918-115X
            #52188
            Ian S C
              @iansc
              Add to the Southbend book, ‘How to Cut Screw Threads in the Lathe'(Bulletin no 36A published 1938), its only 20 pages, but like ‘How to Run a Lathe’ an excellent little book. There are a number of other South Bend Books,ie., No. 38 ‘How to Grind Lathe Tool Cutter Bits’.
              Another one I got soon after I got my lathe was Stan Bray’s ‘Introducing the Lathe’.Ian S C
              Edited By Ian S C on 28/05/2010 09:34:53
              #52264
              John Coates
                @johncoates48577
                As a recent entrant into this fascinating hobby (I’m not into models but the engineering bit using lathes and mills) I was faced with where to start
                I have bought many books and would recommend the following (some of which are also recommended by others above)
                The Amateur’s Lathe by L H Sparey (an excellent overview)
                Lathework a Complete Course by Harold Hall (Workshop Practice no.34 I think)
                The Model Engineers Workshop Manual by Geo Thomas (more info than a Tibetan monk could digest in a lifetime on a mountain top, absolutely amazing book and thanks for the folks on here who recommended it)
                My two penneth’ worth
                Clive Turnbull
                  @cliveturnbull59507
                  Thanks all,
                  I have plenty to go at now, so will head down to my vintage bookshop and also the library. Check out the titles  and then buy what I think suits my knowledge.
                  Cheers
