Proxxon Chuck PCD
Proxxon Chuck PCD
Home Forums General Questions Proxxon Chuck PCD
  • #600054
    Neville Chase
      @nevillechase52412
      Hi everyone. Can someone please tell me the PCD is of the Proxxon 24036 four jaw chuck? Also the dimensions of the register on the back would be very helpful.
      Thanks
      Neville Chase
        @nevillechase52412
        #600127
        bernard towers
          @bernardtowers37738
          Can’t you just measure the pod? And as for the register it’s not the size that matters it’s the FIT!
          #600138
            Posted by bernard towers on 31/05/2022 21:44:44:
            Very philosophical … but: being a mass-market device, one might reasonably assume that Proxxon has design tolerances for the parts [such that components are interchangeable]
            Neville Chase
              @nevillechase52412
              If I had something to measure I would have done that. I want to see if I can adapt this chuck to another machine, which is why I am asking.
              #600171
              Neville Chase
                @nevillechase52412
                This is the chuck –
                #600173
                John Hinkley
                  @johnhinkley26699
                  Chronos are advertising them as in stock, as are Axminster. Might be worth a phone call or email? I am assuming from your description that the lathe in question is PD400.
                    Watch this from about 18.20. looks like the register is 40mm and PCD 34mm
                    #600181
                    Neville Chase
                      @nevillechase52412
                      Posted by John Hinkley on 01/06/2022 10:24:05:
                      The chuck is for a PD230/E.
                      #600188
                      John Hinkley
                        @johnhinkley26699
                        Neville,
                        That narrows the search down a bit. Nevertheless, the Chronos pointer was for the quoted 24036 chuck. Seems like Jason has come up trumps, again, though.
                        Neville Chase
                          @nevillechase52412
                          Chronos and Axminster do have the same chuck I linked to on Amazon, but both more expensive than the Amazon one. Axminster not in stock but available to order. Chronos looks like it's in stock. Will contact Chronos for more info on the chuck dimensions.
                          #600344
                          Robin Graham
                            @robingraham42208
                            Hi Neville. From your opening post I assumed that you had some specific need to use the Proxxon chuck. As the thread has evolved it looks like you are planning to buy one, and I wonder why.
                            It may be that you are thinking that because Proxxon stuff is generally well made the 4-jaw will be a cut above the (much cheaper) Chinese/Indian offerings. That is not necessarily true. My first lathe was Proxxon PD400 which came with a really lovely Rohm 3-jaw – smooth and accurate. I ordered a 100mm 4-jaw (~£200) assuming it would be of similar quality. I received a Proxxon branded item which proved a real pain to use – very sticky with screws binding in the casting. The 4-jaw which came bundled with my Chinese lathe is far smoother. Looking at your Amazon link I see two reviews, one saying it's 'well manufactured and functions perfectly' and the other:
                            'The level of "precision" is just atrocious. There are no two jaws that would be of the same height. The machining is just sloppy with a lot of "apprentice marks" like burrs, uneven angles and discoloration from overheating. There is a lot of grinding dust and metal chips in the jaw screw threads. The starts of threads of the jaw screws are misshaped. The screws are binding in the head even without the jaws installed. Hopefully it all can be fixed but the chuck is absolutely not worth the money.'
                            My experience with the PD400 chuck wasn't as dire as that of second reviewer, but closer than that of the first.
                            Apologies if this isn't relevant to the decisions you are making Nevillle, just my two ha'porth (as we're going back to imperial).
                            Regards, Robin.
                            Edited By Robin Graham on 02/06/2022 23:10:28
                            #600371
                            Neville Chase
                              @nevillechase52412
                              Thanks Robyn.
                              Had seen the reviews and was a bit worried about quality. I did buy a Proxxon PD-230E 3 jaw for my Toyo ML-1 lathe recently and that is very good. Fits the Toyo perfectly. Left my run too late for a PD-230/E four jaw as they are now out of stock everywhere I have looked. Was hoping to adapt the PD-250E to the Toyo if I could.
                              #600544
                              Neville Chase
                                @nevillechase52412
                                #600578
                                  Posted by Neville Chase on 04/06/2022 11:20:12:
                                  Found some info on the chuck here –
                                  https://www.naradiprofesional.cz/206109-proxxon-24036-sklicidlo-4-celist-pd-250-e
                                  DeepL translates the tabulated values as :
                                  External Ø 79mm
                                  Inner passage 20mm
                                  height incl. jaws 35mm
                                  So you’re not quite there yet … but it’s probably worth browsing that site for more info.
                                  Neville Chase
                                    @nevillechase52412
                                    I've emailed a couple of places that stock this chuck about dimensions, such as PCD and diameter of mount holes. If the PCD is 35mm I would be very happy.
                                    #600930
                                    Neville Chase
                                      @nevillechase52412
                                      Mounting register for the Proxxon Chuck is 40mm and PCD is 34mm. Toyo spindle is a register of 22mm and a PCD 0f 35mm. That's going to be a challenge.
                                      #600931
                                      Neville Chase
                                        @nevillechase52412
                                        If the PCD was 35mm I could probably make a disc 40mm x 22mm to press into the rear of the chuck. I do make things difficult for myself.
                                        #601069
                                        Neville Chase
                                          @nevillechase52412
                                          I've ordered the Proxxon chuck from Amazon. Plan is to make a back plate for it.
                                          #601376
                                          Graham Meek
                                            @grahammeek88282
                                            Hi Neville,
                                            I have sent you a PM, you may be able to help me.
                                            Gray,
                                            #601420
                                            Neville Chase
                                              @nevillechase52412
                                              Posted by Graham Meek on 11/06/2022 19:41:13:
                                              Hi Neville,
                                              Gray,
                                              Replied to PM.
                                              Nev.
                                              #602113
                                              Neville Chase
                                                @nevillechase52412
                                                Got the chuck today and very happy with it. Just so everyone knows the register depth is 5.8mm and mounting holes are 4mm.
                                                Nev.
