Protective film for polished metal.
Home Forums Beginners questions Protective film for polished metal.
  • #543008
    Robin Graham
      @robingraham42208
      I've been spending some time polishing brass lately. I would like to be able to protect finished parts (flat surfaces, nothing complicated) pending assembly. I had a look for protective film – the sort of stuff that you peel from metal sheets supplied as polished – but found only industrial-quantity suppliers.
      Does anyone know where I could get small quantities? Or are there any suggestions for DIY alternatives? Obviously it's important that the film leaves no discernible residue when peeled off.
      Robin.
      Robin Graham
        @robingraham42208
        #543011
        Pete.
          @pete-2
          Sticky back vinyl wrap should do you, if you're in the UK I could post you a small bit to try.
          #543012
          Keith Long
            @keithlong89920
            What about ordinary kitchen cling-film?
            #543014
            Paul Lousick
              @paullousick59116
              I second the use of kitchen cling film. Not just for polished brass but steel as well to prevent rusting prior to painting. Also use it to wrap finished parts in to prevent scratches and dings.
              #543034
              DC31k
                @dc31k
                The generic search term is 'low tack protection film'. A small roll is available from Toolstation, product code 20527.
                #543036
                John Haine
                  @johnhaine32865
                  Renaissance Wax. Also for final polishing. Google is your friend.
                  #543038
                  Adam Mara
                    @adammara
                    Application tape is probably the answer. Its a low tack adhesive paper used to hold vinyl lettering spacing in situ when applying to the final surface.. No good as a long term solution as the adhesive grips more over time! Lots for sale on Ebay, if you want a sample PM me!
                    #543077
                    mechman48
                      @mechman48
                      +1 for cling film; also try clear auto laquer/ hair spray, if SWMBO will let you use hers, can be easily removed using acetone ( nail polish remover ).
                      George.
                      #543082
                        I would be very wary of the protective films sold by the likes of Toolstation, Screwfix etc as I have found if left for an extended period of time will leave adhesive on the surface. Couple of weeks max is as long as I like to leave them down.
                        #543084
                        Bob Stevenson
                          @bobstevenson13909
                          ….What Jason said!……you can try low tak airbrush film but my expereince has been that the adhesives are a problem with polished brass. I always store finished parts in plastic zip-lock bags with the air pushed out, inside a plastic box.
                          #543091
                          Ron Laden
                            @ronladen17547
                            ARC list MetalGuard, Ultra, not used it but it reads well.
                            Leaves a 2 micron clear film that does not yellow contains corrosion inhibitors for ferrous and yellow metal.
                            #543100
                            John Haine
                              @johnhaine32865
                              Let me reiterate my suggest of Renaissance wax. I doubt that any stick backed film would be suitable for the final assembly, but the surface will need just as much or more protection then.
                              This product is designed for the job, it works very well, no reason why it shouldn't be applied to the parts initially and another treatment when assembled. A small pot is not terribly expensive
                              #543107
                              Dalboy
                                @dalboy
                                Posted by John Haine on 04/05/2021 15:20:47:
                                A very good product have used it many times it also prevents fingerprints showing on the item it is used on. If it is good enough for the British Museum then good enough for me.
                                As for "Not terribly expensive" a pot of 65ml about 10 years ago was about £11 and I still have 1/2 of that left as it does go a very long way
                                #543197
                                Robin Graham
                                  @robingraham42208
                                  Thanks for suggestions.
                                  I had tried clingfilm – I couldn't get it to stick reliably. It is also quite thin at ~ 10μm.
                                  I've used Renaissance wax for metal finishing, and it's good stuff I agree – but not really what I want here. Corrosion isn't the problem, it's a need to protect the work from the scratch demons which seem to inhabit my workshop. Or to put it another way, to protect the work from my sloppy and inconsistent practices.
                                  I have MetalGuard from ARC – it's great for what it's meant for, but it's not what's needed here.
                                  I had thought about painting or spraying with some sort of protective film, but then it has to be removed with a solvent, which would give further scope to the scratch demons.
                                  It sounds like the vinyl transfer tape which Adam suggested might work. I had a look (I wasn't aware of the technology) and have ordered a roll. I went for the brand which had the most negative reviews for the intended purpose – 'not sticky enough'. It won't need it to be in place for more than a few days,
                                  Many thanks to Pete and Adam for offering samples – very much appreciated, but I succumbed to the lure of 'Free delivery: Tomorrow. Order within 14 minutes'. So the stuff should be with me tomorrow – or later today, looking at the clock now.
                                  Robin
                                  Edited By Robin Graham on 05/05/2021 00:13:55
                                  Edited By Robin Graham on 05/05/2021 00:14:43
                                  Edited By Robin Graham on 05/05/2021 00:35:32
                                  Edited By Robin Graham on 05/05/2021 00:50:23
                                  #543198
                                  Bazyle
                                    @bazyle
                                    I think a lot of people were thinking about oxidation as your problem but now you mention mechanical damage as the enemy.
                                    Up to about 30 years ago the engineering company site where I worked still had about 100 people employed in machining, plating and planning support just for making prototypes before it got reduced to one cnc mill and outsourcing. Anyway every sample part you got from said machine shop, even if the next step was to hit it with a hammer, would come nicely wrapped in tissue paper then brown paper held with Sellotape. I think they must have had a special swarf free area to do the clean and wrap operation.
                                    Raw material sheet Al came with one side protected by a self adhesive film, green for hard temper and blue for soft. Even after years this film pulled off without leaving a residue. Must be available somewhere.
