Posted by Raymond Anderson on 23/09/2016 12:33:41:
In response to Js specifically, I get the impression that there are folk on this forum that hang on every word you print. . Well, here is some news to you "I DONT ". When all is said and done I see nothing that you turn out that sets you apart from any run of the mill Turners or Millers You are just an " ordinary " machinist, nothing to set the heather on fire. You are fine when others share you're opinion but the toys and insults get hurled around when others have different views. You certainly have an over inflated opinion of you're worth. Like I said you might have some on here that think you are something special as a machinist , but in the real world an "Ordinary Joe "
At last Raymond, something we both agree on.
I'd be the first to agree on that. People on this forum like Jason absolutely amaze me with that they can do. Even Neil's efforts are far in front of what I could manage given the intricacy and patience required. So yes I'm an ordinary Joe.
I'm don't really care what one person thinks, in this case you because you don't even know your own mind.
In the first post you say ER's are not the best collet system then later after presenting absolutely no evidence what is, you say they are the best for the home shop. What is it to be ?
The fact I mentioned the aerospace company just up the road from me and that many pages later was seconded buy someone else completely went over your head and totally ignored.
Shrink fit was mentioned by you and just glossed over so for all our readers who aren't Google Childs let me explain how a shrink fit holder works.
As the name suggests the cutter is shrunk fitted into the holder, sounds simple ? well it isn't.
For a start the holders are very, very accurately made to very tight tolerances and need certain types of cutters, also made to very tight tolerances to go in there so forget the boot sale cutters we all love.
Then you need an expensive induction heater setup where the holder is heated up and the cutter fitted and allowed to cool.
The type of companies that use these tend to have a trained person, usually in the tool crib or CCM department who's job it is. So he fits the cutter, puts it in a jig and measures the tool offset, marks it up and it goes in a rack or delivered to the machine.
Sometimes that last operation is missed out because machines like 5 axis DGM's now have laser tool length offset measuring built in and that transfers the value to the tool table automatically.
In many cases they will load 5 of the same tool so T10 to T15 will be 10mm cutters and T16 to T20 will be 12mm cutters. The reason for this is the machine monitors the spindle amperage and the only reason for the amperage to increase is a blunt or chipped cutter, so it stops automatically, swaps the tool, rewinds a few lines if programmed to on fault codes and carries on. So often at the end of a job the operator looks at the log and only swaps T10 to T12 and T16 to T18. Often the other tools are in there for months, unused.
Now it's a good system and works well for the big boys.
Where it falls down flat on it's face is cost, having to have a skilled person swap tools and you don't swap them every farts end like we do.
Which one of the two hats do you want me to add as your avatar ?
Edited By John Stevenson on 23/09/2016 22:15:20
