Posted by Raymond Anderson on 24/09/2016 19:02:00:
Thanks for the info re Schaublin. Would that be a "WELDON shank or Whistle notch that Schaublin mention, as it sounds like it.
cheers
Weldon's which incidentally don't mean weld on are the type often just called end mill holders with the side mounted screw and whilst simple they do have known drawbacks.
Firstly they need to be made to a tight tolerance which a lot aren't but more importantly the shank of the cutter also has to be to a matching tolerance and it's an area where manufactures tend to cut corners.
Ideally they should be a tight push fit but too often they will be looser than this with the result that when the side screw is tightened it pushed the cutter off centre with the result that one tooth is doing all the work.
Balance is also a problem. A new one should not have a problem is balanced but if the screw is lost and replaced by a non standard screw then it all goes out the window.
Worse is the cutter, the manufacturer puts a flat on the shank but who's to say how deep and how long ?
In my book, OK for manually hogging on a mill but not for accurate high speed use because of the problems outlined.
