I need some help deciding on the right size propane cylinder to use for general silver soldering jobs in the home workshop.
I will be using the Sievert PMPX kit. I envisage having to use the 4 bar 12kw, 25kw, and 43kw burners at 4 bar on occasion. The first job will be a simple 5 inch copper cornish type boiler. Other jobs are likely to be silvering solder parts, to fist size lumps of mild steel.
I already have a 15kg Butane cylinder. I was hoping to do a direct exchange (without having to buy another agreement) for another Group A Calor cylinder, either the 3.9kg propane or the 13kg propane.I fancy the 3.9kg because it is portable, but was wondering if it is too small and would suffer the inconvenience of quickly running out of gas?.
The 6kg propane cylinder looks ideal, but it is in Group B and requires another one off £30 agreeement charge, so I am discounting that one at the moment. (unless this is THE one to get?)
What cyclinder size are you using in your home workshop? What cyclinder size can you recommend? Is the 3.9kg cyclinder too small? Should I get the 6kg size? Is the 13kg overkill?. Have you experienced freezing with the small size cylinder, or the bigger cylinders come to that?
Many thanks in anticipation of your reply.
Steve
