Prop Size
Prop Size
Home Forums I/C Engines Prop Size
  • #733595
    John Purdy
      @johnpurdy78347
      I’m in the process of making a Sparey 5cc diesel. In the original AeroModeller magazine article of May 1946 Sparey states he uses a 13″ dia. 6″ pitch prop but in Ron Chernick’s build notes on Model Engine News he says he uses a 16″ prop but doesn’t state the pitch. That’s quite a difference. What would/do other people use/think.
      Diogenes
        @diogenes
        Is it likely that Sparey was recommending the smaller for actually flying it, and Ron had fitted the larger one to ‘check’ his engine a bit for the purposes of running-in?
        #733603
        bernard towers
          @bernardtowers37738
          I run mine on a 15 x 6 wood, it runs at just over 5000.
          #733646
          KEITH BEAUMONT
            @keithbeaumont45476
            I  run mine usually with an 16×4 APC nylon and get 5000 RPM. Also Have a wood 14×6 that does not perform as well and sounds different to the 16″.
            Keith
            #733686
            John Purdy
              @johnpurdy78347
              Thanks for your replies. Sounds like a 15 or 16″ one with a 4 to 6 pitch is the way to go. Another question, did you have to open up the hole in the prop hub?  The plans show a 3/8″ dia. prop hub on the engine, but most of the props I’ve seen only have holes of 3/16 or 1/4″ dia. in the hub.
              KEITH BEAUMONT
                @keithbeaumont45476
                I did not follow that route and made a conventional spinner with the same thread as the propshaft. The propdriver face was plunge knurled. Drilling out the prop,with the re-balancing needed does not seem to add anything.
                Keith.
                #733819
                John Purdy
                  @johnpurdy78347
                  Keith
                  That sounds like maybe that is the way to go. Would mean a slight re-design of the front end of the crank so I guess it would be prudent to get the prop first to find the actual size of the hole in the hub (could always be bushed down if bigger I guess).
                  KEITH BEAUMONT
                    @keithbeaumont45476
                    John,
                    I am pretty sure that I made the crankshaft with a 1/4″ BSF thread. I cannot check it at the moment as my garage/workshop door will not open.
                    Keith.
                    #733843
                    KEITH BEAUMONT
                      @keithbeaumont45476
                      John,
                      Forget that. I am pretty sure it was 2 BA now I think back.
                      Keith
                      #733845
                      bernard towers
                        @bernardtowers37738
                        Her indoors changed the locks Kieth?
                        #733848
                        KEITH BEAUMONT
                          @keithbeaumont45476
                          Nothing so simple. It is a 15ft electric Roller Door. The break mechanism has sheared and it came crashing down just as I was about to go under it. It is 8 years old and H&s have changed the system since and I am told no spares are available, so I am in for a new ,expensive ,replacement,
                          Keith
                        Home Forums I/C Engines Topics
