Sorry, yes an ‘iron thermal’ relates to the fact my big glider has a small engine in the fuselage, which can be raised up and run if it all goes to worms. Technically it’s a self-sustainer, in that the motor is quite small, only a few horsepower, and is intended to keep the glider in the air, but not to allow it to take off under it’s own power. Mind you it’s pretty marginal at keeping the glider in the air. If everything is going for you, then the climb rate is about 100 feet per minute. The installation is dead simple, two cylinder two stroke, no throttle, and air start. The big advantage of a self-sustainer is that as far as the CAA, and law, is concerned it is still a glider, so no licence required.
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Terry: I must have been over your place at one point. After I finished getting myself out of the hole at HusBos I was pretty much over the M1, due west of HusBos. I then nipped off to Bruntingthorpe before heading back to Cambridge.
Norman: That’s too accurate a description of the trials and tribulations of field landings to have been made by a non-participant? At least when one of my gliders had the trailing edge of wing eaten by cows it wasn’t me that put it in the field, but my syndicate partner.
PS: Self-sustainers are all the rage now, despite the extra cost. There are probably several reasons. One, it’s a PITA doing retrieves, fuel is expensive, and it means finding people who are prepared to give up many hours of time, as well as debates about who can drive your car. On a more practical note, because of the more unsavoury parts of society, many fields have locked gates or ditches across the entrance that you can’t get a car through. The final blow is that with the amalgamation of farms, at least in East Anglia, the farmer might live many miles away. And he’s not going to leave his supper and a beer just to unlock a gate! The last field I landed in, just to east of Cambridge, had a farmer who lived near Sudbury, a good 20+ miles away.
Edited By Andrew Johnston on 29/08/2011 20:19:56
