Progress with the Progress drill
Home Forums Manual machine tools Progress with the Progress drill
  • #567549
    AJAX
      @ajax
      As mentioned in a previous thread, I am working on refurbishing an Elliott Progress No. 1 Mark 1 bench drill (dated about 1946).
      I have successfully removed the quill and all that remains is the main spindle pulley which is proving very determined to stay put. I should add the pulley spins freely and the bearing feels good, but I wish to remove the pulley so I can strip and paint the whole machine.
      If you look down through the bore you will see a key that engages with the sliding spindle. I can "lock" the pulley by reinstalling the corresponding keyed shaft, but I am reluctant to apply excessive force through this key / shaft.
      At the top of the shaft, there is a part with a left hand thread which I assume locks the step-pulley into place. Incidentally, there is no other obvious way the pulley is locked, such as a grub screw.
      I have attempted to remove the aforementioned locking part using various grips (I don't like doing so, but needs must) before / after applying heat (about 280 degrees) and penetrating oil. If I do get this off successfully, I may make a replacement part that is easier to remove or modify this one so am bar can be inserted for removal.
      If all else fails I could consider cutting the pulley off to get a closer look, but I am very reluctant to do so.
      Any suggestions?
      20211020-075800 20211020-075843 20211021-090320 20211021-090331 20211021-090336 20211021-090400
      AJAX
        @ajax
        One more part to remove
        #567553
        larry phelan 1
          @larryphelan1
          I am surprised that no-one has been able to help with this problem.
          Sad to say, I cannot offer any advice, but someone out there must have come across it before.
          I would be very interested to know just how it,s held in place.secret
          #567557
          Vic
            @vic
            When I took my old Progress number one apart I struggled with one part only to discover there was a really thin snap ring holding it together. Once removed it came apart easily. It was just a very thin split ring of spring steel.
            #567561
            not done it yet
              @notdoneityet
              Well, at a guess, I would say the pulley is on a taper.
              OP refrains from telling us who gave the right info to get the quill out, so I’ll leave to him to find a way of releasing the pulley without damaging/destroying it. I would also suggest that the likely pair of roller bearings should be replaced with new once the machine is dismantled.
              #567563
              AJAX
                @ajax
                Posted by Vic on 21/10/2021 10:10:57:
                Vic, I haven't found any split rings so far but thanks for the heads-up. It didn't retain the pulley did it?
                Edited By AJAX on 21/10/2021 10:51:08
                #567565
                  You may find some comfort in this thread from 2014 : **LINK**
                  https://www.model-engineer.co.uk/forums/postings.asp?th=102236
                  My guess is that the aforementioned left-hand thread is simply very firmly tightened.
                  AJAX
                    @ajax
                    Posted by not done it yet on 21/10/2021 10:43:42:
                    Let me see if I can track down the previous post. But in case the suspense is too great, I discovered the quill return spring "cover" was not removable (despite my best efforts!) but simply knocked through with a tap from the handle side.
                    246434070-599093041523632-6900266691442594882-n
                    #567572
                    AJAX
                      @ajax
                      Posted by Michael Gilligan on 21/10/2021 10:53:02:
                      Thanks, I have now resurrected the old thread. smiley
                      As for "firmly tightened"… It's more like welded on!
                      #567573
                      AJAX
                        @ajax
                        The bottom set of bearings run very smoothly. I'm hoping any more that I encounter when I finally shift the pulley will be the same.
                        If confirmed it is on a taper I may try a new approach, but I'm reluctant to use gear pullers on a fragile cast aluminium pulley.
                        #567577
                          Posted by AJAX on 21/10/2021 11:18:46:
                          It might be worth devising some sort of adapter, and then asking the local tyre fitter to apply their impact wrench.
                          AJAX
                            @ajax
                            Posted by Michael Gilligan on 21/10/2021 11:32:30:
                            An excellent suggestion but I have finally got it off! Holding on to the pulley without damaging it was proving to be a pain until I realized the obvious and got out some rope.
                            20211021-114459 20211021-114535
                            #567594
                              Bravo !!
                              Vic
                                @vic
                                Posted by AJAX on 21/10/2021 10:50:45:
                                Sorry, I can’t remember it was a few years back. Someone else has done a rebuild of a number one on here so maybe worth a search?
                                #567663
                                Pete.
                                  @pete-2
                                  looks like a nice little project, hope we get to see it finished
                                  #567667
                                  AJAX
                                    @ajax
                                    Posted by Pete. on 21/10/2021 23:11:38:
                                    Thanks Pete.
                                    Here are some more photos in case anyone is interested.
                                    The spindle has 2 pairs of bearings and you'll also see the electric motor which came with the drill. I've cleaned the motor up and resprayed, checked the internal wiring, earth leakage testing, etc. I haven't yet decided whether to keep this motor (I have a few others to choose from) or install a 3 phase + VFD instead. I will make that decision later.
                                    20211021-234031 20211021-234039 20211021-234047 20211021-234100 20211021-234107 20211021-234120 20211021-234223 20211021-234236 20211021-235250 20211021-235301 20211022-000652 20211022-000713 20211022-000858
                                    #567682
                                      Great Progress !
                                      … in both senses of that phrase
                                      AJAX
                                        @ajax
                                        I left the paint stripper on overnight and it has softened, but not enough to allow easy scraping/brushing off. I have applied another coat (I don't expect it to make much difference) but also contacted a local shot blasting company to request a quote. Does anyone have a rough idea how much this would cost? £50 – £80 is my guess but I could be way off.
                                        I cleaned up the column (very heavy!) and two step pulleys.
                                        20211022-094352 20211022-111538
