Hi Michael – sounds like you’re having a great time 😊
Again, in my 2G the head is clamped by that one screw.
Assuming you’ve not got the clamps free yet. It’s a cylindrical wedge type of clamp – so the bolt pulls together two floating cylindrical parts, one either side of the column. Both of these are chamfered where they touch and tighten against the column.
BUT, I’m sure does really need saying, the head is very heavy – when I’ve removed it in the past, I have used the small table that is meant to hold chuck keys etc, pushed and clamped up below the head so it can’t fall any further. If yours doesn’t have that, be careful !!
So there is one wedge tapped and another with a clearance hole – perhaps loosen the screw a few millimetres and the hit the screw to push the tapped wedge out of position. If the clearance one is also stuck, belt it with a drift with the tapped wedge out.
If it won’t move then, or you already got that far, I fully agree with Nigel.
Cheers – Will
