Problems with a breadmaker
Home Forums The Tea Room Problems with a breadmaker
Viewing 25 posts - 1 through 25 (of 49 total)
  • #372852
    Gary Wooding
      @garywooding25363
      My wife has been using a Panasonic bread-maker for many years. She always uses the same recipe, brand of flour, and yeast, but the results vary. Mostly the bread rises OK, but has a distinct slope, with one end taller than the other. Once in a while she gets a pretty near perfect loaf, and occasionally it hardly rises at all.
      We've been unable to figure out why the variation and, in particular, why it sometimes hardly rises at all.
      She uses the same brand dried yeast and stores the opened packets in the fridge.
      Any ideas?
      Gary Wooding
        @garywooding25363
        #372855
        Bazyle
          @bazyle
          If it has more than one heater element perhaps one has an intermittent contact so doe not heat up one end, and sometimes more than one fails, or the switch is dodgy.
          #372859
          Bob Stevenson
            @bobstevenson13909
            We also use a Panasonic breadmaker with mostly consistent results, however, it was not always so…..
            I don't think it's a good idea to keep the yeast satchets in the fridge as temp is everything when making bread…we buy the yeast in small regular batches and make sure we only use fresh yeast. we also use the same tepid water temp every time and make sure that the Allinson strong white bread flour is also fresh…ie we don't buy too much at one time. We have also noted that kitchen temp is critical too and make sure it's the same each time we use the machine.
            a friend of ours makes really excellent and tasty bread with her Panasonic maker but has developed her own recipe using equal amounts of white and brown/wholemeal flours
            #372866
            Baz
              @baz89810
              The long suffering ( her indoors) has had a Panasonic bread maker for at least 15 years. Started off with yeast sachets but got variable results, ever since using packet all in one mixes results have been very consistent, machine has one heating element in base and bread rises equally end to end.
              #372868
              Gary Wooding
                @garywooding25363
                I don't think the machine has more than one heater.
                Somebody advised her to store the yeast in the fridge in an attempt to solve the problems I've mentioned, but it had no effect.
                She uses only Carr's flour purchased in 1.5Kg bags, and weighs 10oz of wholemeal and 4oz of strong white per loaf, which she makes every two days. She typically has one opened bag with one unopened in reserve, and always checks that the water is at approx the same tepid temperature every time. There is no heating in the kitchen but there is a doorway (without a door) to a heated room.So the kitchen temperature does vary, but, because it's an old Victorian house it takes a while to respond to the external temperature.
                #372879
                Cornish Jack
                  @cornishjack
                  SWMBO also has a Panasonic (12 years plus) and has mostly good results but occasional, inexplicable oddities – lopsided or heavy texture. Uses Canadian Strong flour and sachet yeast and measures quantities very carefully. No clues, so far, as to the cause of the anomalies.
                  rgds
                  Bill
                  #372881
                  Stuart Bridger
                    @stuartbridger82290
                    I have a breadmaker, but never use it to bake. It makes the dough, which I then cook I the oven. Vastly superior results
                    #372883
                    Vic
                      @vic
                      We’ve had the same problem a few times with our Panasonic Gary and we’ve put it down to stale yeast. We use ours a couple of times a week and get great results from it once we realise the powdered yeast has gone off. My wife uses Sainsbury’s whole meal bread packs that you just add water and butter to but I normally add a little extra yeast to make it rise a little more. “Sloping” loaves are definitely down to not enough rise. Our Panasonic must be over 20 years old now?
                      #372884
                      Vic
                        @vic
                        Posted by The Oily Rag on 23/09/2018 13:25:41:
                        Useful thread for me. I am being pressurised to buy a breadmaker for our kitchen as I am constantly complaining it has been alleged about supermarket bread. Top of our list was the Panasonic machine.
                        regards
                        Ian
                        You don’t want to know what goes in some supermarket bread or where it comes from … wink
                        #372888
                          Posted by Vic on 23/09/2018 15:02:51:
                          I heard a story in my college days that you definitely won't hear repeated on this forum…
                          N.
                          #372892
                          Wout Moerman
                            @woutmoerman25063
                            We aRe on our third Panasonic. We bake daily, sometimes twice. Number one was used until the anti stick coating was gone in many places. That seems to be the weakest part, also in the replacements. But they are really good machines. I guess we get about 1000 breads out of a machine, so that about 10 cent per bread.
                            We vary a lot in recipes and sometimes they breads are even, sometimes not. But it always tastes vastly superior to supermarket bread!
                            #372893
                            KWIL
                              @kwil
                              Batch to batch, flour will and does vary (Source – Friendly Master Baker)
                              #372903
                              Adam Mara
                                @adammara
                                Thought it was me getting inconsistent results with my Panasonic bread maker using recipes, pleased to hear I am not alone. I get far better results from the ready to bake packs, Wrights Mixed Grain is favourite, and has a fairly long shelf life, but always read the instructions, this is what happened when I missed 'use half a pack' on a Ciabatta mix!ciabatta.jpg
                                #372909
                                Mick B1
                                  @mickb1
                                  Posted by Stuart Bridger on 23/09/2018 14:50:49:
                                  +1. I turn it off before the bake starts, then knock the dough flat and roll it up to bloomer shape, let it rise again and bake in the oven.
                                  Mind you, since the sourdough loaves at Lidl, Morries and Sainsbury's have recently become so good, I haven't made any for a while…
                                  #372921
                                  Grizzly bear
                                    @grizzlybear
                                    We have a Panasonic SD 2500 about 4 years old, had a cheapo previously, no comparison.
                                    + 1 for fresh yeast, it soon goes off.
                                    Good results with various makes of flour, usual mix is 300g strong white and 200g of wheat meal or country mix,
                                    not sure of the name, but its coarse. Add honey & olive oil + 260ml of water.
                                    Regards, bear..
                                    Edited By Grizzly bear on 23/09/2018 18:32:20
                                    #372930
                                    Ady1
                                      @ady1
                                      I always thought it was in the kneading of the dough but there's also a bit of alchemy in breadmaking
                                      Like with the making of alloys and steels
                                      My own preference is Hovis White and their consistent results really do astound me
                                      Other mass produced breads just taste like total rubbish to me, even the more expensive stuff
                                      So IMO there's deffo a sprinkling of breadmakers magic in a good loaf
                                      EDIT
                                      With beer I believe the wort is a critical part of the process for consistent results
                                      Edited By Ady1 on 23/09/2018 18:58:11
                                      #372958
                                      Meunier
                                        @meunier
                                        Posted by Ady1 on 23/09/2018 18:56:37:
                                        Have thought often about inconsistent results with our Panasonic machine and believe the consistency you mention is probably due to using large – enormous by home standards – quantities in their mixes where a small variation in quantity has a minimal effect and controlled water/environmental temperatures make the difference. Our kitchen scales quantities and water temperature estimates give a proportionately greater difference than with large mixes.
                                        DaveD
                                        Edited By Meunier on 23/09/2018 20:24:19
                                        #372968
                                        Georgineer
                                          @georgineer
                                          I've been baking our own bread since the village bakery where we then lived closed down. I've worn out two Kenwood machines and am well on the way to wearing out my second Panasonic.
                                          After a lot of experimenting we've settled on 1/3 Waitrose green flour and 2/3 Waitrose orange flour – I've no idea what's in them, I just go by the colour of the packet ! I recently experimented with Waitrose grey flour, which I know is rye. It rises but can't keep the bubbles (not enough gluten) so it sits down again. I was going to add PVA glue but was over-ruled, so I've given up the experiment.
                                          I've found that a draught can affect the loaf – our breadmaker sits next to a window and I have to be sure to close up before baking on a cold or breezy day.
                                          I use Allinsons tinned yeast – Easy Bake I think it's called. A tin lasts me about a month, and the yeast gets noticeably less active toward the end of the tin, which I counteract by gradually increasing the dose.
                                          For water I use filtered tap water which I keep in a jug at room temperature. I don't think the temperature matters, but sometimes our tap water smells of chlorine and that may well upset the megobs.
                                          George
                                          #372972
                                          Mark Rand
                                            @markrand96270
                                            I'm surprised that nobody seems to be keeping a working yeast culture. Why is this?
                                            #372979
                                            Trevor Crossman 1
                                              @trevorcrossman1
                                              Posted by Mark Rand on 23/09/2018 21:58:57:
                                              Most probably because it is not easy to keep such small quantities of live yeast as would be used by a domestic baker working and maintaining a constant culture due to other wild yeasts present. It is much easier to start and maintain a sourdough culture in the kitchen environment, I started mine ages ago, some homes have them handed down from mother to daughter. I stopped baking yeasted breads ages ago and only bake sourdough which produces a more consistent, and to my mind, a better flavoured and more digestible loaf.
                                              Regarding the OP's breadmaker, I don't have one nor see much benefit of them other than using them for the initial proving, and I, as others have mentioned prefer the oven for consistent results. However, perhaps the inconsistent results are due to temperature variation that particular kitchen, due to local air movement, sunshine, other heat sources.
                                              Trevor
                                              #372987
                                              StephenS
                                                @stephens
                                                Posted by Grizzly bear on 23/09/2018 18:27:51:
                                                +1 for really fresh yeast, it is surprising how much it can lose it's effectiveness over a short time period.
                                                Panasonic definitely the best bread-makers.
                                                StephenS.
                                                #373003
                                                Simon Collier
                                                  @simoncollier74340
                                                  Even hand made bread, properly shaped, will invariably (almost) end up asymmetrical. You might check the lid seal to see if anything is jacking it open a little at one end. Make sure water is not too warm and killing the yeast. Have the machine in a draft free place. Mine is in the laundry and I close the window and door when it is on. It will help to activate the yeast first in say, a couple of tablespoons of warm water, one of flour and perhaps a few grains of sugar. Stir, cover and wait till it froths up. Deduct starter ingredients from the total. I weigh everything including water. I keep yeast in the fridge for ages without any trouble, but I mostly only make pizzas these days.
                                                  I have done a lot of beer brewing and baking in the past, and made sourdough as our regular bread for a couple of years. Ultimately, with living cultures, there is a degree of variability you can't control.
                                                  #373013
                                                  Andrew Moyes 1
                                                    @andrewmoyes1
                                                    I put the lopsidedness down to the ball of dough coming to rest on one side of the machine. Adding a tiny bit more water might make it self level a bit more. I’ve also got the impression that adding slightly more water makes a loaves rise more if they are heavy (especially wholemeal). Worth a try. I agree that batches of flour and yeast do vary as well. I’ve used Panasonic for years and it’s the one kitchen gadget that’s stood the test of time.
                                                    #373028
                                                    ChrisH
                                                      @chrish
                                                      Why buy a breadmaker? You don't need one to make bread.
                                                      I use a recipe of 500grams strong bread flour, 500gms plain flour, 3gms salt (to taste, that's good for me), 14gms dried yeast, 2 tablespoons olive oil and about 320-340 gms warm water depending on how the flour takes it. Mix in mixer with dough hook for 10 minutes, let rise in oiled basin at normal kitchen temperature until at least doubled in size, knock down, very briefly hand kneed, divide into size for loaf tins available, let rise again and bake – and great results every time. Mind you, our mixer is a Kitchen Aid which has enough grunt to handle the volume; if yours doesn't do half measures instead, which is what I have to do when in France.
                                                      Simples!
                                                      Chris
                                                      Edited By ChrisH on 24/09/2018 10:16:50
