Problems bending 3/16″ dia copper pipe without kinking
Home Forums Locomotives Problems bending 3/16″ dia copper pipe without kinking
Viewing 3 posts - 26 through 28 (of 28 total)
  • #479726
    Speedy Builder5
      @speedybuilder5
      To the above, bend the tube a few degrees more than you want, then bend it back to correct angle. This also help to release the cord inside.
      Greensands
        @greensands
        I am in also two views as to whether annealing before bending is always a good idea and certainly with the more generous radii it is possible to achieve very good results bending by hand pressure alone using conviently available stub ends etc as mandrels.
        #479755
        Martin Connelly
          @martinconnelly55370
          This is some 1/4" 20swg 316L tube being bent with tooling I made out of CA104 bronze. The machine is an Addison DB89. The tooling consisted of a bend die, clamp die and follower die and were all half round forms fully supporting the outside of the tube. The bend was 3/4" (3D) centre line radius. No mandrel, no filler. Sorry about the quality and colours, it was some years ago and cameras have got better since then.
          Martin C
          Forgot I also made the collet blocks to grip the tube end.
          Edited By Martin Connelly on 14/06/2020 11:07:14
        Home Forums Locomotives Topics
