Posted by Andrew Tinsley on 27/03/2023 11:44:44:
Acetone and my regular ATF fluid are immiscible and separate out in seconds. So what brand of ATF fluid mixes with acetone?
Good question: problem of course is that ATF isn't a single straightforward item, it's shorthand for hundreds of different mixtures. Two fluids with the same specification (as an ATF), can even be made from completely different materials. Quite likely the customer has no idea what's in the can, and the only way to find out if Acetone mixes is to try it.
About 10 years ago I mixed acetone with ATF successfully, so it's not impossible, and it worked OK. Can't find the can in my garage to confirm what it was! A generic brand bought from a motor factor for this purpose, so I can't link it to a particular car. I guess I got lucky. Can't say it worked better than Plus Gas.
It does show how unreliable comparative tables of the 'Penetrating Oils Compared' type are. It says ATF and Acetone are best and that everybody uses it, whilst Andrew reports he can't get the two to mix at all. Like many folk remedies, the specification is inadequate.
Worse, the methodology isn't explained, so we've no idea how fair the result is. Done properly, many thousands of different nuts and bolts have to be corroded together, the liquids applied by someone who doesn't know what they are, and undone by someone who doesn't know either. Small samples in comparisons like this are meaningless. And maybe the test ignores the possibility products are targetted at different types of problem: better at some, less effective on others.
Amateurs love to believe unlikely mixes of cheap traditional products perform better than commercial products. Usually not! ATF containing a lubricant that will be carried deep into a corroded joint by a light spirit like Acetone certainly works, but the fumes and effect on skin may not be safe enough to sell the mix commercially. And what about shelf-life? Acetone is likely to evaporate quickly on the shelf, leaving pure ATF behind in the bottle that won't penetrate next time.
Commercial products are safer, more reliable, and have longer shelf lives. And instructions…
