My Willson lathe has the once-common American L0 long taper spindle. Faceplates and chucks are drawn on to the taper by a large nut whose pull is reacted by a backplate working against a shoulder behind the large end of the taper. Turning the nut the other way causes the backplate to contact the headstock thereby releasing the taper and allowing the faceplate, etc to be removed.
Yesterday, when removing a faceplate I noticed that the nut was unusually stiff to move once the taper was released. Removing the screws retaining the nut left the backplate, which is normally free to rotate, now too stiff to turn by hand (in normal operation the nut/backplate is loosened and tightened with a large C spanner but rotated by hand between the two).
Has any L0 user had this problem, please? And if so can you suggest a solution?
At the time I speculated that the current hot weather might be the cause but the overnight drop in temperature has not caused the problem to go away. I am thinking of holding the backplate stationary with the spanner whilst rotating the spindle slowly under power (and at the same time applying oil) to see whether this will free things up. The daunting alternative would seem to be to strip out the spindle and bore out the backplate.
