Three months back I was asked if I could make 1500 or so Magnetic Stainless Steel buttons from 416 Stainless that were to be attached to various electric motors in a Nuclear power station to enable a magnetic sensor to be attached and removed as required for monitoring purposes.
The job was very simple, consisting of a 23mm diameter X approx 6 mm thick disc with a rough finish on one side and a smooth finish on the other.
First problem encountered after making them was that the powers to be were not happy with the parting pip that had been left, even though they had been dressed off there was still a little raised pip in the centre. They were bought back to me and I re faced all of them with a facing tool and eliminated the problem.
The next problem was very serious and that was that the buttons were rusting, some of them alarmingly so. Fortunately I had the mill certificate for the material so at least I couldn't be accused of substituting stainless with plain mild steel.
Some of the ones fitted showed a complete cover of rust and also some were starting to show signs of rusting in the bag that they were stored in, however one batch of 500 that were completed a few days after the initial batch showed no signs of rust forming. I think though can't be certain that I washed one batch, possibly the first to remove any grease from them because they were to be glued to the motor and I wanted to give it the best chance, I washed them in a strong detergent (Fairy Liquid) and dried them in the oven, it was at the end of this process that I noticed some very small signs of pitting here and there amongst them so I wiped them all clean and sent them off
I thad the ones that were showing signs of rust sent back to me and I took another skim off them.
Yesterday I experimented with various buttons, I soaked two in a mix of table salt and washing up liquid, another couple I soaked for an hour or two in lime juice in an attempt to passivate them, another couple had been laying around the workshop for a couple of months, having been found when sweeping up and another batch I took straight from the machine and placed all of them outside open to the elements.
The results are not promising, the batch that were soaked in washing up liquid and salt had pretty much rusted right over the face, The ones that came straight off the machine were showing signs of slight rust after a few hours, The ones that had been machined a while back were a little less corroded than the freshly machined ones and the ones that I soaked in lime juice were better than the rest other than a slight bit of light rust starting to show on one of them.
The problem looks to be corrosion of free iron after the machining process that has not been removed properly. Would prosper passivating or electroplating improve the corrosion resistance and which would be best?
