Problem setting up stationary engine.
Home Forums Stationary engines Problem setting up stationary engine.
Viewing 6 posts - 26 through 31 (of 31 total)
  • #151005
    FMES
      @fmes
      I can't see very well from your photo, but the norm would be for the screw to hold a bush (a silver bit) that runs in the connecting rod bearing (a brassy bit).
      This screw should be tight to hold the bush and enable it to turn within the rod bearing.
      To be sure, if you could undo the crank screw and do a closeup photo of the crank rod would help to see.
      Brian John
        @brianjohn93961
        Yes, there is a bush in the connecting rod bearing. The Loctite is holding it for now.
        #151021
        NJH
          @njh
          Hi Brian
          " Who sells hexagon headed screws ?"
          I find  THIS guy very helpful. Speedy service and small quantities too.
          Norman
          Edited By NJH on 29/04/2014 12:40:11
          #151041
          FMES
            @fmes
            Posted by Brian John on 29/04/2014 12:23:29:
            Are you saying that you have loctited the bush to the bearing?
            #151060
            Brian John
              @brianjohn93961
              No, I meant that the Loctite is holding the screw in the crank
              #151068
              GaryM
                @garym
                Posted by Brian John on 27/04/2014 22:09:58:
                Hi Brian,
                Sorry I didn't see your question straight away. But here is one supplier of hex headed screws that quite a few people on here use:
                There are plenty of others.
                Gary
              Home Forums Stationary engines Topics
