Andy
A few thoughts ….
Are you aiming to print the items yourself or get them made for you, and what sort of size are you looking at .
If you are looking for a bureau , I have a few friends who have used Shapeways , they provide a good service and online advice.
Home printing using filament FDM 3D printers is practical for objects that will fit within 200mm -275mm cubic build volume. 3D Printers with larger build platforms start getting expensive [unless you make it your self !}
The best material would probably be ABS as this can survive heat better and can be finished to a smooth surface.
You will always have a patterned surface finish with an FDM printer that will need work [post processing] if you want a smooth surface finish.
The Stereolithography 3D printing process will produce much finer results but is more expensive and is really for professional use … or if you are really dedicated !
For ABS you need a printer with a heated bed and for best results an enclosed build space to keep the surrounding air temperature constant ~70C. This helps with curling and similar defects.
A number of cheap 3D printers only work with PLA filament,
If you decide to make them yourself then be prepared for a learning curve and occasional frustration till it comes right !
Steve
