Printing page on digital Model Engineer
Home Forums Subscription issues and Digital magazines Printing page on digital Model Engineer
  • #104878
    Frank Small
      @franksmall87776
      Hi,
      My printer works fine on Word etc but not on Digital Model Engineer.
      My PC OS is Windows 7 Premium Home
      When I select print on the top of the page the menu shows my printer but fails to print.
      When I check in to printer properties the file is not in the queue
      Your advice would be greatly appreciated
      Thank you for your interest
      Frank Small
        @franksmall87776
        #104886
        Steambuff
          @steambuff
          I assume that you mean the "Print this page" button that appears when you click on the page to zoom in .. and not the Windows IE/Firefox print icon.
          Frank Small
            @franksmall87776
            Hi Dave,
            Yes, you are correct
            Do you have a solution?
            Frank
            #104905
            Keith Long
              @keithlong89920
              Hi Frank
              Just tried and printed no problem. I was a bit surprsed at seeing the pages numbers diplayed in the printer dialogue box as "0" but hitting the "OK" button in the dialogue box resulted in a printed page without any problem.
              I'm using Widows 7 starter, running on a Toshiba net book, and Firefox as the browser.
              You might need to check your local settings.
              Keith
              #104910
              Roger Vane
                @rogervane67137
                Hi Frank
                Just tried printing a page from latest MEW – no problems. The dialog box enables me to select a printer (defaults to my inkjet printer (setup under 'printers and devices&#39 and also allows me to 'print to file'. Do you have any problems with these items? Haven't noticed the page number that Keith refers to though.
                Using Windows Home Premium 64 bit and IE9.
                Regards, Roger
                #105307
                Brian in OZ
                  @brianinoz24148
                  Hi Frank,
                  What on earth did you do with your last msg ??
                  ((Posting deleted by Diane))
                  I print from the page viewer though I will say that sometimes a page will take a while to upload and no printing will happen till this is complete. I think it was the previous issue of MEW the "programing person" did not position the "downloading" box very well and it was almost impossible to find (top left corner of the page).
                  Yes, as "Steambuff" says, you print from the page viewer NOT from your browser or operating system.
                  Brian in OZ
                  Edited By Diane Carney on 03/12/2012 17:13:35
                  #110503
                  Henri Vanherle
                    @henrivanherle62394
                    I have problems with printing pages from back issues of Model Engineer's Workshop.
                    Although the "Print Preview" shows the correct pages I want to print, my printer turns out a completely black page. Utterly frustrating and expensive on ink. I guess I'm not using the correct procedure. Which one is?
                    I'm using Windows 7 and my printer works fine for other jobs.
                    Henri
                    #110506
                    David Clark 13
                      @davidclark13
                      Hi There
                      In recent versions of Windows you can electronically turn the screen 90 degrees.
                      I have my monitor mounted on an extending arm so I can rotate it. This is ideal for checking full page proofs.
                      This is sufficient on most modern monitors to display a full magazine page.
                      Then press print screen.
                      Paste this into a paint program as a new image and then you can print it out.
                      regards David
                      #110744
                      Dithering
                        @dithering
                        The "Print" item on the left-click menu doesn't work for me either – I just get a completely black page.
                        However, if you magnify the page you will get a "Print this page" tab appearing at the top. That works OK.
                        Brian.
                        #110745
                        Dithering
                          @dithering
                          Well, almost OK. Although the colour images come out in colour and the black text comes out black, the black diagrams come out in a rather faint green – thus rendering them useless!
                          Brian.
                          #110746
                          Russell Eberhardt
                            @russelleberhardt48058
                            Posted by Frank Small on 28/11/2012 09:48:43:
                            Hi,
                            Check your antivirus. It could be blocking scripts on that site.
                            Russell.
                            #110763
                            Gone Away
                              @goneaway
                              Posted by David Clark 1 on 30/01/2013 15:05:50:
                              But the resolution would be terrible – on a modern monitor – maybe 96 dpi. Even a picture image is rubbish below ~150 dpi for printing (and pushing it at that). For text, I wouldn't bother.
