Printing clock wheels…?
Home Forums 3D Printers and 3D Printing Printing clock wheels…?
  • #31629
    Tony Jeffree
      @tonyjeffree56510
      Tony Jeffree
        @tonyjeffree56510
        Anyone attempted this yet? I have a copy of Art Fenerty's Gearotic (**LINK**) that I have dusted off & updated to the latest version, and have tried printing a couple of test wheels at 1 Module using a fairly coarse setting (0.2mm layers) on my Ender 3. Successfully printed a 60T cycloidal wheel and a supposedly matching 12T pinion, but the tooth form leaves a lot to be desired. Just re-doing the large wheel using 0.1mm layers but it is taking a while – the teeth seem to be "spreading" a little, so the tooth spaces look on the small side. Anyone had any better success?
        #463439
          Hi Tony,
          Do you use Cura?
          I found that a combination of negative 'horizontal expansion' with an even greater level for the first layers to prevent elephant's foot is the solution. You will then find all your less critical prints are better too!
          <edit>
          I have horizontal expansion at -0.05mm with initial layer at -0.15mm, that might be a place to start. Also beware worn nozzles!
          Edited By Neil Wyatt on 09/04/2020 12:20:17
          #463440
          Tony Jeffree
            @tonyjeffree56510
            Hi Neil
            I have Cura but haven't yet got to grips with it – obviously now is the time to start! Thanks for the tip…
            Cheers,
            Tony
            #463524
            Bazyle
              @bazyle
              Since you now have a 'spare' you might try running it in with a metal gear and see if it improves, or degrades, the tooth face. I printed a module 1 gear, photo in my album, which is fine as a changewheel but I think the requirements are more difficult for a clock.
              #463547
              Tony Jeffree
                @tonyjeffree56510
                Posted by Bazyle on 09/04/2020 17:42:07:
                Unfortunately, I don't have any 1 module cycloidal metal gears to run it in with, but yes, if I did, that would be worth a go.
                #463612
                Ronald Morrison
                  @ronaldmorrison29248
                  Another item to consider is the extruder temperature. Not all PLA works well at the same temperature.
                  #466336
                  Danny R
                    @dannyr
                    Hi Tony. I have been producing lots of gears of various types on my home built Prusa type 3d printer and have posted a design hint on Thingiverse that might help you produce better gears. Go to the Thingiverse site and search for "Better 3D Printed Gears" by Danthelad. Instead of making a file with the gear as a parallel sided model (top and bottom) try to put a taper from the base of the teeth to the top of the teeth of about 3 to 5 degrees so that this area is not printed directly from the print plate but is built up gradually. This leaves the tooth area clear of the printing base and does not cause the "Elephants Foot" problem.
                    Hope this helps,
                    Danny.
                    #466351
                    nigel jones 5
                      @nigeljones5
                      Ive seen your gears Dan – good work. I note that you were running with ABS. I tried and it eas a total failure but now ger great results on PLA at very 'loose' setting of 0.3 layer, 10% fill and 205 deg, running at 80mm/s…..i think it runs well because theere is less heat store…keep posting!
                      #466355
                        Experiment, experiment, experiment.
                        If you try different settings, different filaments you will learn what works well for your designs on your printer.
                        And whenever you get below par results when you were expecting better, always suspect a worn nozzle.
                        Enough!
                          @enough
                          Posted by Neil Wyatt on 22/04/2020 18:04:05:
                          I think I've spent 90% of my 3D printer activity on making experiments and 10% on making anything useful.
                          sad
                          #466474
                          Tony Jeffree
                            @tonyjeffree56510
                            Hi Danny
                            Thanks for the tip – I will give that a go.
                            Cheers,
                            Tony
                            #466475
                            Tony Jeffree
                              @tonyjeffree56510
                              Posted by Bandersnatch on 22/04/2020 18:31:29:
                              sad
                              Sounds a bit like the metalworking equivalent – 90% of the time making jigs, fixtures and special tools, 10% making the part you wanted to make in the first place…
