Printed gear tooth templates
Home Forums General Questions Printed gear tooth templates
  • #636593
    Rob McSweeney
      @robmcsweeney81205
      I was watching a YouTube video recently, where the contributor ground a gear cutting flycutter by cutting out a printed profile of the gear tooth and sticking it to the HSS blank. Anyone know where they got the printout from?
      Rob McSweeney
        @robmcsweeney81205
        #636594
        Pete Rimmer
          @peterimmer30576
          Probably GearDXF. Will produce a cad drawing of any supported gear you specify which you can then open and print out.
          #636595
            I've done it by printing out from a CAD drawing. Fusion 360 will do it for free rather than pay for Gear DXF
            Edited By JasonB on 07/03/2023 20:26:16
            #636596
            Pete Rimmer
              @peterimmer30576
              GearDXF is free software Jason.
              https://www.forestmoon.com/Software/GearDXF/
              I note that the newest version now outputs .STL files.
              #636620
              Bazyle
                @bazyle
                In the end they are normally approximated by parts of circles. Therefore you could draw one BIG and reduce it in a photocopier, or by scanning and printing after using your photo programme to shrink it.
                #636624
                Paul Lousick
                  @paullousick59116
                  Another online site for designing spur gears, 3D printing parts and other engineering services is .emachineshop.com (**LINK**) There is a large library of pre-designed parts.
                  Gears can be designed in either inches or mm and exported as dxf or stl format
                  #636634
                    Peter, I was thinking of Gearotec, not GearDXFblush
                    #636666
                    Rob McSweeney
                      @robmcsweeney81205
                      Thank you gentlemen, l will have a play and see how l get on.
                      #636676
                        Do you have a link to the video, were there printed on paper or 3D printed.
                        As I said I have done it and I used paper, don't have a photo for gears but this is one for a form tool, printed 1:1 and cut out a piece, laid that on some gauge plate and used a sharpie to mark where to remove metal. remaining bit of paper can be used to offer the tool upto as you get close to shape..
                        And an internal gear where the cutter was shaped using teh same method
