Pride of Penrhyn Steam Wagon drawing and construction notes
Home Forums Traction engines Pride of Penrhyn Steam Wagon drawing and construction notes
  • #167288
    Mark Salzedo
      @marksalzedo65030
      Hi,
      I've recently bought a part built Winsons/Modelworks 2" Scale Pride of Penrhyn Steam Wagon. I don't suppose any knows where I might source the drawings and construction notes?
      I've tried Engineers Emporium and Steam Traction World but they are unable to throw any light on a source.
      I'm sure there must be someone out there who has or knows of someone who might be kind enough to photocopy. I will obviously reimburse for any costs.
      Do they steam well when complete?
      Many thanks,
      Mark
      Mark Salzedo
        @marksalzedo65030
        #517351
        Chris Martin 2
          @chrismartin2
          Mark,
          I realise your post is over six years old now but I do have a full set of build drawings and instructions should you still require them.
          Chris
          #518061
          Mark Salzedo 1
            @marksalzedo1
            Hi Chris,
            Thank you for your message but I no longer require the drawings. Thank you anyway.
            Mark
            #547671
            aaron Bassett
              @aaronbassett12648
              Hi Chris I do have a POP just wondering if I could have a copy of the drawings and instructions. I have lost mine over the years.
              Many thanks
              Edited By aaron Bassett on 29/05/2021 14:14:54
              #592290
              Neil Bradshaw
                @neilbradshaw24930
                Hi Chris
                Do you anybody else have any plans for this steam wagon
                Thanks
                Chris Martin 2
                  @chrismartin2
                  Neil – I have the drawings and assembly instructions that were supplied with the Winsons Pride of Penrhyn kit, Is it those you require?
                  Aaron – Apologies but I have only just seen your request dated 29/05/2021. Do you still require these?
                  #592747
                  Neil Bradshaw
                    @neilbradshaw24930
                    Hi Chris
                    Could you help me out with some information
                    Could you look at the drawings and see what the part number is for the bracket that is the gear operating hande and I think it is the output shaft bearing its on the left hand side near the gear assembly
                    Thanks
                    Chris Martin 2
                      @chrismartin2
                      I’m not at home for a week or so but will check this for you when I’m back
                      Chris
                      #593043
                      Neil Bradshaw
                        @neilbradshaw24930
                        Hi Chris
                        Fine on you being away
                        I dont need that part number Ive found the part amongst the photographs of parts
                        I know you have offerd the drawings to Aaron if he doesnt need them we can work things out
                        Ive bought the POP from Station Road Steam So Ive just got to wait for delivery and see what Im missing I know the engine and cad sides are missing and the rood=f
                        Catch up when you get back
                        Ules0
                        #593803
                        vic francis
                          @vicfrancis
                          Hi Neil, Julia Old did a extensive build of one of these engines, doing necessary mods to make the engine work. She is on traction talk forum.The series was published on her web site years ago, not sure if I still have it but I will look. She has gradually moved up in scale to little Samson 6 inch scale engine. So is well qualified. I think this engine is based on the Robey steam wagon.The boilers were good, commercially made, but some of the engineering needs work.This wagon was better than some of the locos, I have the tiger tank.! Made by them which is basic compared to armourtek now.
                          I think she stiffened the road springs as we lack of ground clearance with driver on it.
                          Vic
                          #597422
                          Neil Bradshaw
                            @neilbradshaw24930
                            Hello Vic
                            Thanks for the information
                            Im stuck o another problem now
                            I need the dimensions of the gears
                            On e of mine has gone missing Im not sure if Ive lost it or somebody took a liking to it
                            Im not going to mention where it was but most of my friends are disgusted.
                            Ive got 3 to work of but I need dimensions so I can figure ot which one is missing then I can get a new one made
                            Thanks again
                            David Wager
                              @davidwager24238
                              Hello there – l am a new member to the forum – with my grandson we have just made a move into a slightly larger live steam model – we have a Winson kit built PoP steam wagon but we have no paperwork – l would appreciate any assistance and advice available plus access to a set of instructions and drawings to the original build. Thankyou
                              #657296
                              STEVE JONES
                                @stevejones95764
                                Hi
                                Everyone im looking for a set of drawings for the winson penrhyn and if there ever was any a set of operating instructions.
                                Many thanks in advance
                                Steve
                                #658566
                                David Wager
                                  @davidwager24238
                                  David Wager – Hello Steve l have not had any luck so far in my search for instructions or drawings but l believe there is a published book out there written by an engineer who stripped down and successfully rebuilt one of the Pryde of Penryn models.
                                  If anyone knows of this publication or has one l would be very pleased to hear from them through the forum.
                                  Cheers and heres hoping.
                                  David.
                                  #658621
                                  Chris Martin 2
                                    @chrismartin2
                                    David and Steve, sorry but only just seen your posts. I have all the original supplied drawings and instructions – and a not yet completed kit!
                                    Let me know what you’d like and I’ll scan to a pdf file if that’s ok for you
                                    Chris
                                    #658692
                                    David Wager
                                      @davidwager24238
                                      Hello Chris many thanks for your reply – l purchased a completed but unused PoP earlier this year but l have nothing in the way of paperwork so l would really appreciate any and everything you have as a pdf.
                                      Many thanks again.
                                      David.
                                      #658712
                                      STEVE JONES
                                        @stevejones95764
                                        Hi
                                        Chris
                                        That's Amazing I would really appreciate a copy of the instructions and any paperwork relating to the vehicle.
                                        Its been hard work trying to deal with issues not having any reference this would be a major help in getting my PoP up and running ready to show next year.
                                        Massive Thank you
                                        Steve
                                        #658722
                                        David Wager
                                          @davidwager24238
                                          Good morning Steve – sounds as though you and l am in a similar situation. Perhaps we can use this connection to keep in touch, as l said in my first post, buying the PoP is a big step up from the many Mamod and Wilescos that l have been collecting for my grandson Toby. We are very keen to get things moving and hopefully attend some local shows next summer.
                                          Cheers David.
                                          #658734
                                          Chris Martin 2
                                            @chrismartin2
                                            If you both let me have your emails iI'll send all info to you
                                            Chris
                                            #658746
                                            David Wager
                                              @davidwager24238
                                              Morning Chris – Many thanks indeed – my email is a bit long winded
                                              anymoreforthe.skylark@btinternet.com
                                              Cheers David.
                                              #693206
                                              BC Prof
                                                @bcprof
                                                Chris . I have sent you a PM
                                                #694804
                                                BC Prof
                                                  @bcprof
                                                  POPs are built to last . Started to take my ” only just running ” version apart ( the piston blow by was as loud as the blower at 30 psi on air )  Took off the LH  tank and extracted the seized  hand pump.  It is made from a lump of brass the weighs 1.028kg !!!!!
                                                  #694836
                                                  BC Prof
                                                    @bcprof
                                                    Thanks  Chris  for the drawings  and notes.
                                                    In search of some piston seal the pistons had to come out.
                                                    Rather than take all the valve gear apart  I took off the front cylinder covers
                                                    unscrewed the grub screws from the crossheads  and using two holes drilled into the piston faces I was
                                                    able to unscrew the piston rods from the crossheads ,  As expected  the O  rings were, shall we say, not of a circular
                                                    cross section .  Now the choice is  either  just replace the O rings  or make new pistons and fit proper rings .
                                                  Home Forums Traction engines Topics
