Posted by John Haine on 20/08/2014 21:56:02:
Borax? Doesn't flux stop surfaces oxidising?
As far as I understand it fluxes can perform two roles, iron oxide softens and dissolves or melds into the flux, secondly the flux forms a barrier for oxygen possibly aided by the presence of dissolved iron oxide.
Some antiscale formulas seem to work mainly by stabilising the oxide layer so that it does not flake, an unbroken layer helps to inhibit further oxidation, I suspect others lean more towards dissolving oxides quickly but not necessarily inhibiting their formation. Two mechanisms the balance between the two is likely to vary from formula to formula.
Interesting to note how vitreous enamel ground coats work on steel – the formulation is designed to absorb iron oxide the formation of which is welcomed since the subsequent pitting of the steel is thought to be what allows the ground coat to afix itself to the steel. Seen from this angle it eats its own footholds and handholds by absorbing oxides that in turn are due to oxygen feeding on steel.
When ground coat is detached from the steel after say a sharp blow from a hammer the steel will often be exposed as a silver virgin metal although very pitted and cratered. Borax is one of the ingredients of enamel ground coats and I have heard knife makers moan that despite its abilities as an antiscale they dislike its tendency to pit the steel.
At elevated temperatures oxygen is a savage beast, it will eventually get through most thin layers you care to put in its way so for most diy pastes and mixes I dont think its so much a question of "stopping surfaces oxidising" so much as slowing oxidation, preventing fresh metal being exposed (physical stabilisation of existing oxide layers or fluxes that melt and coat) and making sure that the inevitable oxides lift cleanly or are softened* saving on clear up operations.
* One formulation I have experimented with still left a modest oxide layer although of a slightly lighter grey appearance than usual – I thought the formulation had failed until I tried a very weak acid followed by gentle wire brush and found that its scrubbed off more like a stuborn paint than the usual rock hard and tenacious black scale. The measures mentioned would have had no impact on the scale I usually encounter.
