Pretty new to this
Pretty new to this
  • #611637
    Neil Taylor
      @neiltaylor16781
      Hi all, I’m pretty new to machining and was searching the net regarding a slipping clutch on my ml7 and it led me here so I joined up,it would be great to learn more from you guys so please be aware there may be some stupid questions in the near future
      thank you for your time
      Neil Taylor
        @neiltaylor16781
        #611675
        noel shelley
          @noelshelley55608
          Hi Neil, welcome, have you solved the clutch issue ? The ML7 clutch can be fun, it's a neat idea using a moped brake ! Best wishes Noel
          #611678
          Swarf, Mostly!
            @swarfmostly
            Good afternoon, Neil,
            Just in case it might help:
            Best regards,
            Swarf, Mostly!
            #611686
            magpie
              @magpie
              No such thing as a stupid question if you don't know the answer Neil.
              Dek.
              #611694
              Neil Taylor
                @neiltaylor16781
                Hi guys
                the clutch is a lot better, there’s still some meat on moped pads but when they need replacement I’ll definitely be using villiers as it’s local, thanks for the exploded diagram also, there’s a lot of niddly issues on the lathe as I brought what I could afford but they will get sorted, all the best to you guys
                tha you for your warm welcome
                #611697
                Bootlegger Blacky
                  @bootleggerblacky
                  EBay item number…..234669193975
