Posted by DMB on 31/08/2022 21:19:55:
Lets suppose that the small piston is .5" dia. and wears evenly around its circumference by .0005". That would mean an annular gap that amounts to the piston having worn by a thousandth of its original diameter. My guess is that would result in tears of fluid appearing similar to small leaks seen during actual boiler testing and would represent a tiny error….
Makes sense to me.
My understanding is these devices work by applying pressure to a vertical piston of known area that's supporting a known weight – pounds per square inch. When the pressure lifts the piston off it's seat, the pressure must be the weight on the piston divided by the area of the piston. There's not much to go wrong and a well-made instrument is capable of defining pressure with extreme accuracy.
How about a leaky instrument? The pressure needed to lift the piston is still the same, but to maintain the pressure, the operator has to pump in more fluid to replace the leaked volume. A leak makes the instrument harder to operate, less certain, and reduces the time in which the pressure is stays stable. But I think even an instrument with a moderately bad leak would work well enough to calibrate a Bourdon gauge provided the leaking fluid was replaced steadily.
Commercial gauges are designed for accuracy, fine adjustment, and ease of use ; they have to be kept in good order and leaks are bad news. I think a home-made dead weight gauge could be better for calibrating model engine gauges than a wonky commercial item because home-made can be designed to compensate for leaks whilst remaining more than accurate enough for the purpose.
To me the give away that commercial dead weight testers are over the top for model engineering purposes is the need to compensate them for temperature, density of the fluid, air-pressure and humidity, and the local gravitational field. This is proper metrology rather than engineering, far more accurate than the best Bourdon Gauge or Safety Valve.
That's the idea, but I'm not expert in this field! It would need to be proved by building a leak-compensating gauge, using it to calibrate many ordinary gauges, and then comparing them against a trustworthy standard. If the leak-compensating gauge calibrations a found to be consistently 'close enough', then the machine is acceptable. I'm reasonably confident it would be because much of the early work on pressure measurement was done with relatively crude equipment.
