Posted by S K on 05/03/2023 08:30:02:
I noted about 6 microseconds RMS noise in the ~1.5 second period of my (genuinely) free pendulum. I don't know if this is good or bad, but I did see that the CERN dude's clock has what appears (casually) to be a little higher noise.
Anyway, I think the noise can be reduced further….
If it is anthropogenic (e.g. traffic), then I've also wondered if some mechanical isolation would help. I had presumed that any isolation such as rubber under the base would hurt by sapping the pendulum of energy, however minutely, but I could try something quick and dirty to see what happens.
I did think of doing a spectrum analysis, but as there's no impulse mechanism, I can't record for very long. …
Good to see SK being sucked into the Time Nut Club!
FFT first, yes but to get enough data it will be necessary to impulse the pendulum. Not difficult, but one is left wondering how much noise is due to the impulses, and how much is due to the pendulum! Various sources already mentioned, such as traffic and air movement, but also the knife-edges cutting into the plinth and twisting because the alignment isn't perfect. The tripod probably vibrates because it isn't perfectly rigid, and like as not the floor it's stood on is bendy too.
High-precision clocks are often located in solidly built cellars, or deeper. I believe the BIPM clocks are 24 metres below ground to minimise surface vibration. Another way is to isolate the platform by digging a trench around it, say 300mm wide by 1500mm deep.
Some problems require the clock to be moved geographically. Some sea-side locations move enough with the tide to cause trouble, and micro-gravitational changes have been blamed on ground water moving tidally – some types of rock are full of water.
Practically I'm stuck with my home, and it's not good for this. Best I can do at the moment is a windowsill, which is mechanically stable and convenient, but the temperature varies. When the clock is working properly, I shall move it under the stairs and order visitors to tread lightly!
I have rubber feet under my clock, but they're a compromise. The benefit is they help to isolate the clock from a moving house; the disbenefit is they reduce Q by soaking up energy from the pendulum.
I've hit compromise problems repeatedly whilst trying to design my clock. For example, I know:
- a spherical bob is aerodynamically better than a cylindrical bob, but also that
- a heavy bob is better than a light one.
Which leaves an awkward question: will my pendulum improve if I reduce the weight of it's cylindrical bob to make it aerodynamic, or do the two effects cancel each other out, and it's not worth bothering? Maybe chamfering the ends of a cylinder would be a good compromise – I don't know.
The recent high vs low amplitude debate is another example. Harrison, a genius, described a high-amplitude system which no-one adopted, but has since been found to work. Everyone else built clocks with low-amplitude pendula, which also work extremely well. Is one system better than the other? I think the truth is that the high-amplitude approach solves one set of problems whilst creating another, and so does low-amplitude. Neither is perfect. As there isn't a simple clear winner, yer pays yer money and yer takes yer chances. However, I vote for low amplitude clocks because they're easier to make!
