“but that is meaningless if the parts are being produced en mass by
unqualified people which is probably the case with oriental products.”
To me, that is a very unjustified comment.
Almost anywhere in the world nowadays, mass production is carried out using CNC machining centres, very rarely controlled by skilled setters any more, but semi skilled workers.
All the main work is done off floor by programmers.
Where the difference occurs is in the assembly of the items. Remember the word ‘assembly’, because that is where the main difference lies.
In the far east, hobby machines are usually ‘assembled’ not ‘fitted’ together. That is the major factor. The bits are put into position, just to make sure they fit together and left at that
If you are willing to carry out that fitting yourself, then go for something made in the far east and save yourself loadsa money.
If you are incapable of doing that, then you are at the mercy of companies who will supply you with a ready fitted machine (Myford for example) and you will be paying for that ‘fitting’ together. Way over the top in most cases. Plus, unless you can keep up with adjusting the machine, which needs to be done regularly, you will just end up with another load of castings that are no better than the assembled machines from the far east.
In fact you will be worse off, because again using Myford as an example, designed well over 60 years ago and too small for the larger engineering projects that we get up to. When you can buy a far eastern machine for a third of the price that comes with everything already on board, plus double the swing.
I know which one I will go with.
You have to accept that resting on your reputational laurels only goes so far in this day and age, value for money makes more of an impact.
Just give it a few more years, when the far east starts to sell ‘fitted’ hobby machines, then the ‘elitist’ band of engineers will certainly know their days are numbered.
You could see how it was going fifteen to twenty years ago. Very poor quality machine tools and tooling were coming in, but now things are 1000% better, and getting better all the time. Forty years ago, who in their right mind would have bought Japanese precision instruments, now everyone clamours after them, saying they are the best thing since sliced bread.
The far east are already doing fantastic fitting and setting on semi industrial and industrial machines. A lot more than you think, hobby machines and tooling are just a cheapo sideline to them.
I bought a semi industrial mill for one third the cost of one produced over here, and that was delivered and has been running for nearly two years with no fitting or adjustments required at all, except for one bearing, which was a ten minute job and didn’t have to be done, just me being picky.
It had been set up and fitted perfectly.
Don’t be like the three monkeys. No matter what you do, they are here, and here to stay, and will only improve as time goes on.
Don’t get me wrong, I have had ‘badged’ machines and worked on many more, but what I see now is the beginning of the end for the home country hobby machine producers who think that their products are better than everyone else’s.
When it came to rebuilding my shop, ready for retirement and taking on a few outside jobs, it was a choice of either buying one badged machine or a fully kitted shop with all the tooling and machines, it was a brain deader choice, and I have now jumped on the far eastern bandwagon, and haven’t regretted it one bit.
Bogs
