Steve, as a retired employee of LEICA I can tell you that Leica is owned by the Schmidhieny Brothers based in Heerbrugg in Switzerland.
By buying out LEITZ they aquired Leica Cameras as well.
The basis of this was that the Electronic Microscope business was not big enough for two manufacturers, That is Cambridge Instruments and Leitz .
Cambridge Instruments is also a Leica holding and work is shared between the two.
Leica have several sub manufacturing concerns in Singapore and in China and also Japan.
One of these is Panasonic, who make a lot of optical glass for Leica and assemble electronic and optical lenses for sale under the Leica name. All HIGH quality gear.
Leica cameras is run as a seperate company on its own but is located in the UK at Milton Keynes along with the Leica Microscopy and Leica GeoSystems that deal with the surveying side.
Leica is at the forefront of electro/optical and mechanical excellence and cannot be bettered.
I enjoyed my 25 years with them and covered many different fields in the company.
I started work with them when they were called Wild Heerbrugg and learnt from the bottom up and now I can take a Theodolite down to the last grubscrew and rebuild it and calibrate it along with all the other instruments as well.
We all went to Heerbrugg for factory training on new or induction training.
90% of the techs. are fully trained machinists and familiar with all machinery they are likely to meet. This plus the basic knowledge makes them good engineers with a high degree of Finesse,
Before I joined them I had spent 22 years in the Technical side of the British Army as an Instrument Tech. in REME. This took me all over the world and I initially retired from them in 1977 and then retired from Leica in 1999, I now work at the age of 74 in a subsidary of Leica here in Kent carrying out much the same work I did bfore I left Leica.
clive
